On 05/08/2007 at 02:30, xxxxxxxx wrote:
User Information: Cinema 4D Version: V9.5 Platform: Language(s) :
--------- when I was change the viewport that one viewport to others( top => front ) using : static void SetActiveViewProjection( LONG iNUM = 0 ) { BaseDocument* doc = GetActiveDocument(); LONG lngIndex = 0; lngIndex = iNUM; BaseDraw *bd = doc->GetActiveBaseDraw(); switch( lngIndex ) { case 0: { //BaseDraw *bd = doc->GetBaseDraw( 0); GeData da(BASEDRAW_PROJECTION_PERSPECTIVE); bd->SetParameter(DescLevel(BASEDRAW_DATA_PROJECTION),da,NULL); } break; case 1: { //BaseDraw *bd = doc->GetBaseDraw( 1 ); GeData da(BASEDRAW_PROJECTION_TOP); bd->SetParameter(DescLevel(BASEDRAW_DATA_PROJECTION),da,NULL); } break; case 2: { //BaseDraw *bd = doc->GetBaseDraw( 2); GeData da(BASEDRAW_PROJECTION_RIGHT); bd->SetParameter(DescLevel(BASEDRAW_DATA_PROJECTION),da,NULL); } break; case 3: { //BaseDraw *bd = doc->GetBaseDraw( 3); GeData da(BASEDRAW_PROJECTION_FRONT); bd->SetParameter(DescLevel(BASEDRAW_DATA_PROJECTION),da,NULL); } break; case 4: { //BaseDraw *bd = doc->GetBaseDraw( 3); GeData da(BASEDRAW_PROJECTION_LEFT); bd->SetParameter(DescLevel(BASEDRAW_DATA_PROJECTION),da,NULL); } break; case 5: { //BaseDraw *bd = doc->GetBaseDraw( 3); GeData da(BASEDRAW_PROJECTION_BOTTOM); bd->SetParameter(DescLevel(BASEDRAW_DATA_PROJECTION),da,NULL); } break; case 6: { //BaseDraw *bd = doc->GetBaseDraw( 3); GeData da(BASEDRAW_PROJECTION_PARALLEL); bd->SetParameter(DescLevel(BASEDRAW_DATA_PROJECTION),da,NULL); } break; case 7: { //BaseDraw *bd = doc->GetBaseDraw( 3); GeData da(BASEDRAW_PROJECTION_BACK); bd->SetParameter(DescLevel(BASEDRAW_DATA_PROJECTION),da,NULL); } break; case 8: { //BaseDraw *bd = doc->GetBaseDraw( 3); GeData da(BASEDRAW_PROJECTION_MILITARY); bd->SetParameter(DescLevel(BASEDRAW_DATA_PROJECTION),da,NULL); } break; case 9: { //BaseDraw *bd = doc->GetBaseDraw( 3); GeData da(BASEDRAW_PROJECTION_FROG); bd->SetParameter(DescLevel(BASEDRAW_DATA_PROJECTION),da,NULL); } break; case 10: { //BaseDraw *bd = doc->GetBaseDraw( 3); GeData da(BASEDRAW_PROJECTION_BIRD); bd->SetParameter(DescLevel(BASEDRAW_DATA_PROJECTION),da,NULL); } break; case 11: { //BaseDraw *bd = doc->GetBaseDraw( 3); GeData da(BASEDRAW_PROJECTION_GENTLEMAN); bd->SetParameter(DescLevel(BASEDRAW_DATA_PROJECTION),da,NULL); } break; case 12: { //BaseDraw *bd = doc->GetBaseDraw( 3); GeData da(BASEDRAW_PROJECTION_DIMETRIC); bd->SetParameter(DescLevel(BASEDRAW_DATA_PROJECTION),da,NULL); } break; } //DrawViews(DA_ONLY_ACTIVE_VIEW|DA_NO_THREAD|DA_NO_ANIMATION ); //EventAdd(); EventAdd(EVENT_FORCEREDRAW);
} but the result is not I want that reset the setting positon and lost my effects viewport as have been setted . how to get myviewport like f1, f2, f3, f4.
