On 22/07/2007 at 01:52, xxxxxxxx wrote:
User Information: Cinema 4D Version: Platform: Language(s) : C.O.F.F.E.E ; C++ ; XPRESSO ;
--------- I want to render the object and display the progress with model. but I have an little problem that can't implement display the progress. since I am an newcome student about c4d, how can I to modify the code section : AddUserArea( PREVIEW_AREA_ID, 0, m_bmp->GetBw(), m_bmp->GetBh()); AttachImage(PREVIEW_AREA_ID, m_bmp, 0); this is my all code modifly after : #ifndef __RENDER__COMMON__H #define __RENDER__COMMON__H #include "c4d.h" #include "c4d_symbols.h" #include "c4d_general.h" #include "c4d_baseobject.h" class PreviewAreaBmp : public GeUserArea { public: AutoAlloc<BaseBitmap> m_pBmp; public: // we only need to overload a few functions... Bool Init(void) { BaseDocument* doc = GetActiveDocument(); BaseContainer rdata = doc->GetActiveRenderData()->GetData(); // initialize the bitmap if( !m_pBmp || m_pBmp->Init( rdata.GetLong(RDATA_XRES), rdata.GetLong(RDATA_YRES) )!=IMAGE_OK ) { return false; } return true; }
virtual Bool Init(LONG x, LONG y, LONG depth = 24) { // initialize the bitmap BaseDocument* doc = GetActiveDocument(); BaseContainer rdata = doc->GetActiveRenderData()->GetData(); if( !m_pBmp || m_pBmp->Init( x, y,depth ) != IMAGE_OK ) return false; return true; }
virtual void Draw(LONG x1, LONG y1, LONG x2, LONG y2, LONG flag = 0 ) { // if we have a valid bitmap, render it into the specified region if( m_pBmp ) { DrawBitmap( m_pBmp, x1, y1, x2-x1, y2-y1, 0, 0, m_pBmp->GetBw(), m_pBmp->GetBh(), BMP_NORMALSCALED | BMP_ALLOWALPHA ); } this->Redraw( TRUE); } virtual BaseBitmap* GetBitMap() { BaseBitmap* bmp = NULL; m_pBmp->CopyTo( bmp ); return bmp; } }; ////////////////////////////////////////////////////////////////////////////////////////////// class ModalRenderer : private GeModalDialog { private: BaseDocument* m_doc; BaseContainer m_rdata; String m_title; Bool m_showerrors; PreviewAreaBmp m_bmparea; Real m_p; LONG m_result; enum { SCROLL_GROUP_ID = 100000, PREVIEW_AREA_ID, DLGGROUP_ID, MAIN_GROUP_ID }; class RenderThread : public Thread { private: ModalRenderer* m_dlg; public: RenderThread(ModalRenderer* dlg) : m_dlg(dlg) {} virtual ~RenderThread() { m_dlg = NULL; End(); Wait(FALSE); } virtual void Main() { if (!m_dlg) return; // Start render /*MessageDialog("SETP_ ThreadMain()!");*/ LONG result = RenderDocument( m_dlg->m_doc, m_dlg->m_rdata, ProgressFunction, m_dlg, m_dlg->m_bmparea.m_pBmp, m_dlg->m_showerrors, (BaseThread* )this->Get()); if (m_dlg) { m_dlg->m_result = result; } } virtual const CHAR *GetThreadName(void) { char szThreadName[128]= {0}; char *p = NULL; //GET THREAD NAME //RETURN p = szThreadName; return p; } private: // Called by RenderDocument now and then static void ProgressFunction(Real p, void* dlg) { static_cast<ModalRenderer*>(dlg)->m_p = p; } } m_rt; friend class RenderThread; public: ModalRenderer() : m_doc(NULL), m_p(0.0), m_result(NOTOK), m_showerrors(TRUE), m_rt(this) { } virtual ~ModalRenderer() { ShutdownThread(); } // Render document 'doc' with settings 'rdata', // displaying a progress windows with 'title' and // optionally not showing error messages. Bool Render(BaseDocument* doc, const BaseContainer& rdata, const String& title = String(), Bool showerrors = TRUE) { if (!doc) return FALSE; if ( m_rt.IsRunning() ) { return FALSE; } m_doc = doc; m_rdata = rdata; m_title = title; m_showerrors = showerrors; Bool success = Open(); ShutdownThread(); return success && GetResult(); } //---------------------------------------------------------------------------------------------------- private: // Build the dialog virtual Bool CreateLayout() { if (!InitBitmap()) return FALSE; SetTitle(m_title); GroupBegin(MAIN_GROUP_ID, BFV_SCALEFIT | BFH_SCALEFIT, 1, 0, "", 0); { GroupSpace(4,4); ScrollGroupBegin(SCROLL_GROUP_ID, BFV_SCALEFIT | BFH_SCALEFIT, SCROLLGROUP_STATUSBAR | SCROLLGROUP_BORDERIN | SCROLLGROUP_NOBLIT); { //@@@@@@@@ at here is my modify, // I have been added to class PreviewAreaBmp //but is fail from [email protected]@@@@@@@@@@@*/
//AddUserArea( PREVIEW_AREA_ID, 0, m_bmp->GetBw(), m_bmp->GetBh()); //AttachImage(PREVIEW_AREA_ID, m_bmp, 0);
AddUserArea( PREVIEW_AREA_ID, 0, m_bmparea.m_pBmp->GetBw(), m_bmparea.m_pBmp->GetBh()); AttachUserArea( m_bmparea, PREVIEW_AREA_ID); } GroupEnd(); AddDlgGroup(DLG_CANCEL); } GroupEnd(); return TRUE; } // Init dialog and start render virtual Bool InitValues() { UpdatePreview(); SetTimer(500); Bool success = TRUE; if (!m_rt.IsRunning()) { success = m_rt.Start(TRUE); } return success; } // Ask if the render is running virtual Bool AskClose() { if (!m_rt.IsRunning()) return FALSE; return !QuestionDialog("Do you really want to abort the rendering?"); } // Deal with close box and cancel button problems virtual LONG Message(const BaseContainer &msg, BaseContainer &result) { // Workaround for bad base class implementation if (msg.GetId() == BFM_ACTION && msg.GetLong(BFM_ACTION_ID) == IDC_CANCEL) { return Command(IDC_CANCEL, msg); } else if (msg.GetId() == BFM_CHECKCLOSE) { return AskClose(); } else { return GeModalDialog::Message(msg,result); } } // Check for cancel button virtual Bool Command(LONG id, const BaseContainer& msg) { if (id == IDC_CANCEL && !AskClose()) { ShutdownThread(); return Close(FALSE); } return FALSE; } // Run every 500 ms... virtual void Timer(const BaseContainer& msg) { UpdatePreview(); UpdateStatus(); CheckFinished(); }
// Create preview bitmap Bool InitBitmap() { m_bmparea.Init( m_rdata.GetLong(RDATA_XRES), m_rdata.GetLong(RDATA_YRES) ); return true; } // Tell the preview to redraw itself void UpdatePreview() { //GetUserArea is error from compile /*GeUserArea* ua = GetUserArea(PREVIEW_AREA_ID);*/ //if (ua) ua->Redraw(TRUE); m_bmparea.Draw( 0, 0, m_rdata.GetLong(RDATA_XRES), m_rdata.GetLong(RDATA_YRES) ); //m_bmparea.Redraw( TRUE ); } // Set new statusline text void UpdateStatus() { String txt; if (m_p != 1.0) { txt = "Rendering: " + LongToString(m_p * 100) + "%"; } else { txt = "Finished!"; } BaseContainer msg(BFM_SETSTATUSBAR); msg.SetLong(BFM_STATUSBAR_PROGRESSON, TRUE); msg.SetString(BFM_STATUSBAR_TXT, txt); msg.SetReal(BFM_STATUSBAR_PROGRESS, m_p); SendMessage(SCROLL_GROUP_ID, msg); } // Wait until render thread is stopped void ShutdownThread() { m_rt.End(); m_rt.Wait(FALSE); } // Check if the render is finished void CheckFinished() { if (!m_rt.IsRunning()) { Close(m_result == RAY_OK); } }
// Internal class with render thread // So that the internal class can access private variables }; #endif /////////////////////////////////////////////////////////////////////////////////////////////// void ModulRender() { BaseDocument* doc = GetActiveDocument(); BaseObject* null = doc->GetActiveObject(); if (!null) return; BaseContainer rdata = doc->GetActiveRenderData()->GetData(); BaseBitmap* bmp = BaseBitmap::Alloc(); bmp->Init(rdata.GetLong(RDATA_XRES), rdata.GetLong(RDATA_YRES)); RenderDocument(doc, rdata, NULL , NULL, bmp, TRUE , NULL); bmp->Save( GeGetStartupPath() + "test_modul.jpg", FILTER_JPG, NULL, SAVEBIT_32b*tchANNELS); ShowBitmap(bmp); BaseBitmap::Free( bmp ); ModalRenderer mr; Bool success = mr.Render(doc, rdata, null->GetName(), TRUE); MessageDialog("Finish!"); }
On 22/07/2007 at 02:00, xxxxxxxx wrote:
note: the originality data like this. from http://www.plugincafe.com/forum/display_topic_threads.asp?ForumID=4&TopicID=656&SearchPagePosition=1&search=ModalRenderer&searchMode=allwords&searchIn=Thread&forum=0&searchSort=dateDESC&ReturnPage=Search private: BaseDocument* m_doc; BaseContainer m_rdata; String m_title; BaseBitmap* m_bmp; Bool m_showerrors; Real m_p; LONG m_result; enum { SCROLL_GROUP_ID = 100000, PREVIEW_AREA_ID, DLGGROUP_ID, MAIN_GROUP_ID };
