On 22/07/2007 at 01:00, xxxxxxxx wrote:
User Information: Cinema 4D Version: Platform: Language(s) : C++ ;
--------- I can to add an new camera? but can't get target object to display in showmap()? some anyone can help me? the code bellow : bool DoAddCamera() { MessageDialog("AddCamera START!"); BaseDocument* doc = GetActiveDocument(); BaseObject* null = doc->GetActiveObject(); if (!null) return false; CameraObject* cam = (CameraObject* )BaseObject::Alloc(Ocamera); if ( !cam ) { MessageDialog("CameraObject Create Fail!"); return false; } doc->InsertObject(cam, NULL, NULL); Vector objvcr = null->GetMg().off; Vector camvcr; camvcr.x = objvcr.x - 500; camvcr.y = objvcr.y + 500; camvcr.z = objvcr.z - 500; cam->SetPos( camvcr ); cam->SetRot(Vector(-0.8, -0.6, 0)); // Set rotation (radians, HPB)
cam->SetZoom( 1.0 ); cam->SetAperture( 36.0 ); cam->SetFocus( 36.0 ); cam->SetEditorMode( MODE_ON ); AutoAlloc<BaseLink> link; link->SetLink( null ); cam->SetParameter(DescID(TARGETEXPRESSIONTAG_LINK), GeData(link), NULL); EventAdd(); // Active the camera BaseObject* oldcam = doc->GetActiveBaseDraw()->GetSceneCamera(doc); doc->GetActiveBaseDraw()->SetSceneCamera(cam); // Create some temporaries for the render BaseContainer rdata = cam->GetData(); BaseBitmap* bmp = BaseBitmap::Alloc(); bmp->Init(400, 400); DrawViews(DA_FORCEFULLREDRAW); bmp->Save( GeGetStartupPath() + "test_camera.jpg", FILTER_JPG ,&rdata, SAVEBIT_32b*tchANNELS); // Active the old camera doc->GetActiveBaseDraw()->SetSceneCamera(oldcam); DrawViews(DA_FORCEFULLREDRAW); ShowBitmap(bmp);
BaseBitmap::Free( bmp ); MessageDialog("AddCamera End!"); }
On 22/07/2007 at 11:39, xxxxxxxx wrote:
DrawViews() only causes a redraw in the View editor. It does not create a render nor does it create a bitmap. You need to do a render - ala RenderDocument(). And then you need to get at the render bitmap.
On 22/07/2007 at 18:58, xxxxxxxx wrote:
hi Robert, thank you for your help. but how can I get the originality snapshoot from the editviewport and to save it as..
On 31/07/2007 at 00:59, xxxxxxxx wrote:
I have been solved the problem, it have to render. but set the Basecontain as editor. this code: void Snapshoot( char FileName[] ) { MessageDialog("Snapshoot START!"); BaseDocument* doc = GetActiveDocument(); if (!doc) return; //get active object BaseObject* null = doc->GetActiveObject(); if (!null) { null = doc->GetFirstObject(); if (!null) { return; //have't object } }
//get render data where container value of RDATA_RENDERASEDITOR setting true that status is edit and get snapshoot , can't to render BaseContainer rdata = doc->GetActiveRenderData()->GetData(); //set to render as editor , is control code, must to SET TRUE, // otherwise is render.
rdata.SetBool(RDATA_RENDERASEDITOR, TRUE); // Set render settings rdata.SetFilename(RDATA_PATH, Filename(null->GetName())); //BaseBitmap* bmp = AllocBaseBitmap(); BaseBitmap* bmp = BaseBitmap::Alloc(); BaseBitmap* desbmp = BaseBitmap::Alloc(); bmp->Init(rdata.GetLong(RDATA_XRES), rdata.GetLong(RDATA_YRES)); desbmp->Init(rdata.GetLong(RDATA_XRES), rdata.GetLong(RDATA_YRES)); RenderDocument(doc, rdata, NULL, NULL, bmp, TRUE , NULL); bmp->Save( GeGetStartupPath() + "test_modul2.jpg", FILTER_JPG, NULL, SAVEBIT_32b*tchANNELS); if ( bmp ) { bmp->ScaleBicubic( desbmp, 0,0, bmp->GetBw(), bmp->GetBh(), 0, 0, 400, 400); }
//ShowBitmap(bmp); if (bmp) { bmp->ScaleBicubic( desbmp, 0, 0, bmp->GetBw(), bmp->GetBh(), 0, 0, 400, 400); desbmp->Save(GeGetStartupPath() + "test_modul3.jpg", FILTER_JPG, NULL, SAVEBIT_32b*tchANNELS); } BaseBitmap::Free( bmp ); BaseBitmap::Free( desbmp ); MessageDialog("end !"); }
