On 13/07/2007 at 16:45, xxxxxxxx wrote:
User Information: Cinema 4D Version: 10.111 Platform: Windows ; Language(s) : C.O.F.F.E.E ; XPRESSO ;
--------- Hi,
I wondered if there is some function in C.O.F.F.E.E. that works like the RangeMapper node in XPresso. Especially I am looking for a possibility to use a spline curve , just like in the node.
Is there anything I could use?
Best regards, Jack
On 16/07/2007 at 01:08, xxxxxxxx wrote:
no, you have to write your own. you could use a dummy splineobject to read out interpolated inbetween points though. as long as you don't insert it into the document it will be invisible to the user.
On 16/07/2007 at 02:03, xxxxxxxx wrote:
Hi Matthias,
I was hoping for an answer from you Actually, I take the occasion as a good reason to get into C++
And there I immediately get new problems with VisualC++ 2005 Express. Maybe you'll here from me some more times.
Best regards from Braunschweig, Frank
On 20/07/2007 at 07:14, xxxxxxxx wrote:
Howdy,
A range mapper is fairly easy to code:
if((inMax-inMin) != 0) //Check for division by 0 { mix = (input-inMin)/(inMax-inMin); } else { mix = 0; } output = outMin + mix * (outMax-outMin);
Adios, Cactus Dan
On 23/07/2007 at 00:04, xxxxxxxx wrote:
Hey Dan,
yeah, without the spline function, it is quite easy. Thanks for the code! But since I want to use especially the spline of the Range Mapper node, I can't use it.
Anyway I started learning C++ for CINEMA 4D SDK (learning by doing), so I will do everything different as I planned.
Thanks for your help!
Greetings, Frank
