Plugin upgrade to SDK10
On 13/07/2007 at 04:26, xxxxxxxx wrote:
Cinema 4D Version: 10
Hi all,I have a command plugin written under the SDK9.1. Now, I want to upgrade SDK 10.
I have the plugin and an other application (APP), which communicates the plugin via a dump file. Always the APP starts the communication, APP calls the maxon and sends the path where the plugin can find the dump file.
This is the my plugin class:
class Exchange : public CommandData { public: virtual Bool Execute(BaseDocument *doc); virtual void Message(const BaseContainer &msg;); };
and implementation of Message:
void Exchange::Message(const BaseContainer &msg;) { String mess; String cmdline = msg.GetString(0); // <-- here get the path!! // DocPath and TmpPath CHAR tmpPathBuffer[1024] = { 0 }; // UNITS LONG pos = 0; LONG unit = 0; // default -> no unit // "@" behind the path ? if ( cmdline.FindLast( "@", &pos; ) ) { // space behind the "@" ? if ( pos+1 < cmdline.GetLength() ) { // get unit from string String strUnit = cmdline.SubStr( pos+1, cmdline.GetLength()-pos-1 ); unit = strUnit.StringToLong(); } // clean path by cutting off the unit cmdline = cmdline.SubStr( 0, pos ); } // get paths from command string cmdline.GetCString( tmpPathBuffer, 1024 ); // and so on.. }
And my problem is
void CommandData::Message(BaseContainer& msg) was changed to LONG CommandData::Message(LONG type, void* data)
Now, how can I get the message which contains the path?Thanx,
and have a nice day.
On 13/07/2007 at 08:25, xxxxxxxx wrote:
you must type cast the void pointer to the according data (or to CommandInfoData) and check what message has been sent I assume. Maybe you can also directly cast the pointer to a BaseContainer.
It´s looong time I created a CommandData plugin so this is all just guessed (but you definetly need to type cast the pointer, that´s for sure).
Maybe the support can help.
On 14/07/2007 at 04:51, xxxxxxxx wrote:
Thanx again, works fine...
