Deleting folders and contents issue
    On 06/07/2007 at 14:05, xxxxxxxx wrote:
    Cinema 4D Version:   R8.2-R10
    A user of my plugin notes that when a file 'thumbs.db' exists in a folder, he can't delete the folder completely from within my plugin. I can only think that either the file is being protected from deletion or that it is not being listed by the BrowseFiles interface.
    Here is the general code being used to delete a folder and all contents (files and subfolders, recursively) :
    // v1.1.7
    // Delete Folder from Runtime Library
    Bool IPPDialog::DeleteFolder()
         // Valid Selection?
         RuntimeItem*     folder =     root.GetSelectedFolder();
         if (!folder)     return TRUE;
         RuntimeItem*     parent =     folder->GetParent();
         // Only delete below library and sub folders
         if (folder->IsTypeOf(ITEMTYPE_RUNTIME))     return TRUE;
         if (parent == folder->GetRuntime())          return TRUE;
         // Are you sure?
         if (!QuestionDialog(GeLoadString(IPPS_REMPOSE_YESNO)+"\n\""+folder->GetName()+"\""))     return TRUE;
         Filename     folderFile =     folder->GetFilename();
         if (!GeFKill(folderFile, TRUE))
              // Are you REALLY sure? (folder is not empty)
              if (!QuestionDialog(GeLoadString(IPPS_DELFOLDER_REALLY)))     return TRUE;
              // Backward-Recursively delete subfolders and files in this folder
              if (!DeleteFolderContents(folderFile))     return FALSE;
              GeFKill(folderFile, TRUE);
         // Update Display
         root.SetSelected(NULL, SELECTION_NEW);
         root.Fold(parent, FALSE);
         root.Fold(parent, TRUE);
         root.SetSelected(parent, SELECTION_NEW);
         return TRUE;
    // v1.1.7
    // Delete Folder contents from Runtime Library - recursive
    Bool IPPDialog::DeleteFolderContents(const Filename& folder)
         AutoAlloc<BrowseFiles>     browse;
         if (!browse)     return FALSE;
         Filename          file;
         BOOL               isdir;
    #ifdef     C4D_R10
         browse->Init(folder, BROWSEFILES_SUPPRESSCACHING);
    #else
         browse->Init(folder, FALSE);
    #endif
         while (browse->GetNext())
              file =     folder+browse->GetFilename();
              isdir =     browse->IsDir();
              // Delete Folder's contents
              if (isdir)
                   if (!DeleteFolderContents(file))     return FALSE;
              // Delete Folder or File
              if (!GeFKill(file, isdir))          return FALSE;
         return TRUE;
    Any information on why this occurs and how to work around it is much appreciated!
    Thank you very much,
    Robert
