VPBuffers
    On 29/08/2007 at 08:49, xxxxxxxx wrote:
    Hello Philip,
    where:
    LONG subcnt = layer->GetLayerCount();
    subcnt always is -1 so the internal cycle go in loop forewer.
    What's mean that GetLayerCount() return -1 ?
    cheers
    Renato
    On 29/08/2007 at 11:08, xxxxxxxx wrote:
    But Philip did this in his loop:
    for (j=0;j<subcnt || subcnt==-1;j++)
    Probably explicitly to avoid the infinite loop. No idea about what -1 represents here though.
    On 29/08/2007 at 11:35, xxxxxxxx wrote:
    Hello dear Robert,
    but when the subcnt == -1.. it loop
    renato
    On 29/08/2007 at 12:29, xxxxxxxx wrote:
    Are you sure of your types (LONG)? In actuality, all that is needed is:
    for (j = 0; j < subcnt; ++j)
    Since -1L is less than 0L, the loop should exit immediately. But if ULONG is used, -1L is of course 4 billion.
    All else failing, just check for -1 on subcnt and avoid the loop altogether:
    if (subcnt < 0)     continue;
    for (j=0; j!=subcnt; ++j)
    On 30/08/2007 at 01:54, xxxxxxxx wrote:
    My excuses... one line of source code was missing!
         LONG j,i,id;
         LONG cnt = b3d->GetLayerCount();
         for (i=0; i<cnt; i++)
              MultipassBitmap *sublayer,*layer = b3d->GetLayerNum(i);
              if (!layer) continue;
                   if (subcnt>0)
                        sublayer   = layer->GetLayerNum(j);
                   else
                        sublayer = layer;
                   if (!sublayer) continue;
                   id = sublayer->GetParameter(MPB_USERID).GetLong();
                   if (subcnt==-1) break;
    On 30/08/2007 at 11:10, xxxxxxxx wrote:
    Hello Philip,
    ok now :) but the objectID are the only buffers not detected with this way :(
    any suggestions?
    Renato
    On 30/08/2007 at 14:25, xxxxxxxx wrote:
    To retrieve the alpha channels use:
    cnt = b3d->GetAlphaLayerCount();
         B3dBitmap *layer = b3d->GetAlphaLayerNum(i);
         if (!id) continue;
    On 30/08/2007 at 14:26, xxxxxxxx wrote:
    Ah.. thanks.. i forgot that ObjectID are in fact alpha channels :)
    Thanks a lot
    Renato
