ModellingCommand, container IDs?
On 19/06/2007 at 14:07, xxxxxxxx wrote:
Cinema 4D Version:
Platform:
Language(s) :
Hello.
I'm trying to call the EditSpline:project function using SendModellingCommand. To do this I need to set a LONG(
MDATA_SPLINE_PROJECTMODE)
in the basecontainer of the   ModelingCommandData. How can I figure out which values of MDATA_SPLINE_PROJECTMODE that correspond to which projection mode? The docs only say "see dialog", but I don't see how that helps me?
/Filip
On 19/06/2007 at 16:44, xxxxxxxx wrote:
What it should say is "see dialog and then see resources". :)
When there is a set of constant defines they will almost always be listed in either the _api class headers or in the res or modules folder in the Resource folder.
In this instance, "Projection Mode" is found under the Project command (Structure->Edit Spline->Project).
And the relevant file is:
Resource:Modules:Modeling:Res:Description:toolsplineproject.h
#ifndef _ToolSplineProject_H_
#define _ToolSplineProject_H_
enum
     MDATA_SPLINE_PROJECT_MODE                                        = 2022, // LONG
          MDATA_SPLINE_PROJECT_MODE_VIEW        = 0,
          MDATA_SPLINE_PROJECT_MODE_XY           = 1,
          MDATA_SPLINE_PROJECT_MODE_ZY           = 2,
          MDATA_SPLINE_PROJECT_MODE_XZ           = 3,
          MDATA_SPLINE_PROJECT_MODE_X_AXIS       = 4,
          MDATA_SPLINE_PROJECT_MODE_Y_AXIS       = 5,
          MDATA_SPLINE_PROJECT_MODE_Z_AXIS       = 6,
          MDATA_SPLINE_PROJECT_MODE_SPHERICAL    = 7,
#endif // ToolSplineProject
On 20/06/2007 at 01:02, xxxxxxxx wrote:
That's exactly what I needed. Thanks a lot!
/Filip
