On 03/06/2007 at 18:59, xxxxxxxx wrote:
User Information: Cinema 4D Version: 9.6+ Platform: Language(s) :
--------- Hi all,
How i can detect that a scene is saved in a project? I suppose that must be check in the NODEDATA::write. I need to copy all IES light files in the project folder when saved.
Thanks in advance Renato
On 04/06/2007 at 04:55, xxxxxxxx wrote:
BaseDocument::GetDocumentPath() can be used to determine if the scene is/has been saved to disk. If not, the Filename is empty:
if (!doc->GetDocumentPath().Content()) GePrint("Unsaved Document");
Don't know if there is a means to determine if saved as a project into a folder. But the files should be local to the .c4d document if saved either way.
Hth,
On 04/06/2007 at 06:38, xxxxxxxx wrote:
Thanks Robert,
so i can put in write a copy for these files in the documentpath
Thanks Renato
On 04/06/2007 at 08:06, xxxxxxxx wrote:
Hi All,
this code seem to work.. except that the doc path is the older path and not the new path. How can i get the saved path?
Filename docpath = hf->GetDocument()->GetDocumentPath(); BaseContainer *data = ((BaseObject* )node)->GetDataInstance(); myIesFile = data->GetFilename(VRAYLIGHTTAG_IES_FILE); docpath = docpath + myIesFile.GetFile(); GeFCopyFile(myIesFile,docpath,FALSE); data->SetFilename(VRAYLIGHTTAG_IES_FILE,docpath); return TRUE;
cheers Renato
On 04/06/2007 at 10:25, xxxxxxxx wrote:
What do you mean by 'older path' and 'new path'? Are you trying to do this *while* saving the document? That's gonna be difficult as DocumentPath probably hasn't been updated yet - probably after the save is complete.
The only other possibility is the MSG_DOCUMENTINFO sent when a document is loaded, saved. Check the docs for that one.
On 04/06/2007 at 10:29, xxxxxxxx wrote:
Thanks Robert, i'll do
Cheers Renato
