On 22/05/2007 at 08:16, xxxxxxxx wrote:
User Information: Cinema 4D Version: 10 Platform: Windows ; Language(s) : C++ ;
--------- Hi,
how to enable/disable (i mean to put in inactive and than in active state) descriptions elements like SHADERLINK, REAL, etc.
On 22/05/2007 at 11:31, xxxxxxxx wrote:
I found the answere here
but still don't know how to use it
i have sth like this: Bool test = GetDEnabling(node, DescID(MATERIAL_BUMP_MIPFALLOFF2), GeData("false"), 0, data);
and SDK says: "Just read the passed t_data if the right id was provided, and return TRUE to enable the parameter or FALSE to disable it depending on the value."
and my t_data is here GeData("false") and i doesn't work. I've tried everything.
On 22/05/2007 at 11:39, xxxxxxxx wrote:
GetDEnabling() allows you to change the state from editable to non-editable (greyed-out). This is a virtual method that you add to your data class (see NodeData in the docs) - you can't 'call' it as it is handled by Cinema 4D internally.
Inside, you return TRUE (enable) or FALSE (disable) based upon the description element ID:
/ NodeData.GetDEnabling //*---------------------------------------------------------------------------* Bool IPPFigure::GetDEnabling(GeListNode* node, const DescID& id, GeData& t_data, LONG flags, const BaseContainer* itemdesc) //*---------------------------------------------------------------------------* { if (!node) return FALSE; switch (id[0].id) { // Quick BodyPart Traversal Buttons case IPPFIGURE_BP_UP: return (upBP_ID >= 0L); case IPPFIGURE_BP_DOWN: return (downBP_ID >= 0L); case IPPFIGURE_BP_PREV: return (prevBP_ID >= 0L); case IPPFIGURE_BP_NEXT: return (nextBP_ID >= 0L); // Assorted case IPPFIGURE_COPYMORPHS: { BaseContainer* bc = ((BaseTag* )node)->GetDataInstance(); if (!bc) return TRUE; if (bc->GetBool(IPPFIGURE_CONFORMED)) return TRUE; return FALSE; } case IPPFIGURE_BULGEFACTOR: { BaseContainer* bc = ((BaseTag* )node)->GetDataInstance(); if (!bc) return TRUE; if (bc->GetBool(IPPFIGURE_BULGE)) return TRUE; return FALSE; } case BODYPART_BULGEFACTOR: { BaseContainer* bc = ((BaseTag* )node)->GetDataInstance(); if (!bc) return TRUE; if (bc->GetBool(BODYPART_BULGE)) return TRUE; return FALSE; } case IPPFIGURE_POLYCOUNT: case IPPFIGURE_UNDOS: return FALSE; default: break; } return SUPER::GetDEnabling(node, id, t_data, flags, itemdesc); }
You didn't try this?
On 22/05/2007 at 13:07, xxxxxxxx wrote:
That was very helpfull. Thanks a lot.
