On 17/05/2007 at 12:27, xxxxxxxx wrote:
User Information: Cinema 4D Version: C10 Platform: Windows ; Language(s) : C.O.F.F.E.E ;
--------- Hello, I'm new here. Is it ok if I'm bad in english?
I just have a question:
I'm using GetBit(BIT_ARDATA) to get the Active Render Data with doc->GetFirstRenderData->GetBit(BIT_ARDATA); but the result ist always 0. it doesn't matter if i select the first render data in menu or not. I've noticed it that it works only in Cinema version 9.6.
Seems it is a bug? Or did I do something wrong?
thanks very much!
On 17/05/2007 at 13:51, xxxxxxxx wrote:
COFFEE hasn't yet been updated for R10 - at least the lack of COFFEE docs for R10 suggests this.
R10 has many changes that not even we C++ developers have control of yet. And there are changes that may have impact otherwise. For instance, BaseList2D::GetBit(BIT_OFOLD) and other manager fold bits no longer work in R10. These are now handled through GeListNode::GetNBit() (R10 ONLY!).
So it is possible that you are experiencing something similar - but without an updated COFFEE for R10 it will be difficult if not impossible to work around.
On 18/05/2007 at 03:08, xxxxxxxx wrote:
this is a bug in the current cinema version
On 23/05/2007 at 00:40, xxxxxxxx wrote:
found out that there is a new symbol in Cinema4D R10. use BIT_ACTIVERENDERDATA instead of BIT_ARDATA.
On 01/06/2007 at 11:33, xxxxxxxx wrote:
thank you very much!!!
