On 17/05/2007 at 08:44, xxxxxxxx wrote:
User Information: Cinema 4D Version: 9.6 Platform: Windows ; Language(s) : C.O.F.F.E.E ;
--------- Hello,
How Can I simple create a object only with points (no polygons)?
On 18/05/2007 at 02:18, xxxxxxxx wrote:
Here is a script that creates an points-only object (a sine curve). Have a look at the comments and the COFFEE docu.
var op = AllocObject(Opolygon); if(!op) return; var vc = new(VariableChanged); if (!vc) return FALSE; //VariableChanged is needed for changing the point count var cnt = op->GetPointCount(); vc->Init(cnt,100); op->MultiMessage(MSG_POINTS_CHANGED,vc); var n=0; var points = op->GetPoints(); cnt = op->GetPointCount(); for(n=0; n<cnt; n++) //iterating over the point array and changing of the point values { points[n] = vector(n,10.0*sin(float(n/float(cnt))*pi2),0); } doc->StartUndo(); doc->AddUndo(UNDO_OBJECT,op); op->SetPoints(points); //write the point array back to the object op->Message(MSG_UPDATE); doc->AddUndo(UNDO_OBJECT_NEW,op); doc->InsertObject(op,NULL,NULL); doc->EndUndo();
On 18/05/2007 at 04:04, xxxxxxxx wrote:
thx, works fine !
