On 13/05/2007 at 16:33, xxxxxxxx wrote:
Cinema 4D Version: All
Platform:
Language(s) :
Howdy,
OK, I know from a previous post that the 4th digit indicates whether the serial number is temporary or permanent, and that the 4th digit should be the only digit that changes between a customer's temporary number and permanent number. Is this always the case? My plugin's serial number check is set up to ignore the temporary digit.
I seem to get a few, not many, that register with a temporary number, and then tell me that the number doesn't work. Then they'll say, "Oh, I made a mistake and sent you my temporary number. Here is my permanent number." The permanent number they send is then a totally different number, not just a 4th digit change.
Is this a con, or can the numbers sometimes be that different from the temporary number to the permanent number? I have many customers who I've registered their temporary number and they've never had any problems after receiving their permanent number.
I'm considering not registering any more temporary numbers.
Adios,
Cactus Dan
