export script
On 04/05/2007 at 07:02, xxxxxxxx wrote:
hi,
I whould like to create a export script from C4D into a self created format for use in a game. I have googled for long time, but I cannot find a place to begin. Maybe some really really basic code to start from whould be great.
thanks
Krox
On 04/05/2007 at 08:04, xxxxxxxx wrote:
C4D uses COFFEE as its script language and it does support import/export scripts (FilterPlugin).
Go to the download page and grab either the COFFEE_SDK_95.zip (HTML) or COFFEE_SDK_95.chm (Windows help file). There are examples to help you get started.
On 05/05/2007 at 03:59, xxxxxxxx wrote:
yeah thx a lot... its working 🙂
On 06/05/2007 at 08:17, xxxxxxxx wrote:
well... now I've got a menu entry like "file -> export -> MyExport", and I even figured out, how to write into the resulting file, but i failed to find out, how to get information about the scene i want to save. I'm using
class MyFilter: FilterPlugin
   public:
   Save(doc,fname,obj,mat,env,dialog);
   // many other things go here
I think, the information i need is somewhere inside the MyFilter::Save function parameters, but the filterPlugin class isnt documented in the SDK...
On 06/05/2007 at 09:27, xxxxxxxx wrote:
The 'scene' is the 'doc' argument. A BaseDocument represents the scene (objects, tags, materials, shaders, etc.).
So, say you want to save objects from the scene. You take 'doc' and start traversing the object tree:
var op = doc->GetFirstObject();
while (op)
     // Do your thing here (call a function to export data for instance)
     // Traverse object tree (scene graph)
     if (op->GetDown())
          op = op->GetDown();
     else
          while (!op->GetNext())
               op = op->GetUp();
          if (op) op = op->GetNext();
You'll find more useful information in the SDK Help forum.
On 06/05/2007 at 14:24, xxxxxxxx wrote:
thx again 🙂
On 17/05/2007 at 06:06, xxxxxxxx wrote:
hm... me again 🙂 :
I've been working with "COFFEE SDK 95.zip" for a while now, but it seems very incomplete for use as a reference, so I tried out the "COFFEE SDK 95.chm", but that file is corrupt (and even looks too small, 683 KB). Any idea where to get a working one, oder what other reference to use?
On 17/05/2007 at 06:13, xxxxxxxx wrote:
I just downloaded the file and it is working without problems. It is a compiled HTML file (CHM) thats why it is so small. If you are a Mac user you need a special CHM reader application to read CHM files.
cheers,
Matthias
On 17/05/2007 at 06:54, xxxxxxxx wrote:
accuratly speaking, I am a Linux user. C4D runs on windows which runs inside a virtual machine... but neither there nor on a "real" windows it could be displayed correctly. Anyway, I solved the probelm by installing a chm reader on linux, and it works 🙂
weird thing... but nevermind anymore *g*, thx
