On 02/03/2007 at 02:30, xxxxxxxx wrote:
User Information: Cinema 4D Version: R 10 Platform: Windows ; Language(s) : C++ ;
--------- Hi,
I have a question about CTrackData and how to allocate instances of it. I know there is the
AutoAlloc<PluginTrack> track(pluginid); track->InsertSequence(seq);
for the old animation plugins. But I can't find the corresponding CTrackPlugin class. There is a CTRACKPLUGIN struct but it hasn't got access to the CTrack-methods I want.
Basically what I want is to allocate my own plugin tracks and then add some keys to them. In order to do that I must first be able to allocate a track, insert the track into my object allocate keys and insert them into the track.
I'd like a way to do this with my own tracks:
CTrack *track = CTrack::Alloc(node,id); node->InsertTrackSorted(tmp); CKey *key = track->GetCurve()->AddKey(someTime); key->SetValue(track->GetCurve(),someValue);
Has anyone got some tips in this matter?
Thanks /Jonas
On 06/03/2007 at 05:28, xxxxxxxx wrote:
Here a little example how to allocate the Blinker track from the SDK examples.
BaseObject *op = doc->GetActiveObject(); if(!op) return TRUE; CTrack *mytrack = CTrack::Alloc(op, DescLevel(1001152,1001152,0)); if(!mytrack) return FALSE; op->InsertTrackSorted(mytrack); return TRUE;
You have to pass the plugin ID within the DescLevel function.
On 06/03/2007 at 23:56, xxxxxxxx wrote:
Thanks alot for this Matthias.
/Jonas
