On 26/01/2007 at 20:22, xxxxxxxx wrote:
User Information: Cinema 4D Version: 9,1 Platform: Windows ; Language(s) : C++ ;
--------- Hi,
i've just started with the C++ Cinema SDK.
How can i change a value of an Object?
For example the Radius of a Sphere or the texture filename of a Channel.
I understand that i can get a container by calling BaseObject::GetData() and use this container to change values. But I don't know where i can find the values (IDS) for a given object.
Sorry for my english
On 26/01/2007 at 22:11, xxxxxxxx wrote:
the easiest way to obtain the description IDs is to drag the description element into the Console input field.
for instance to change the radius of a sphere your code should look like this:
BaseContainer *data = op->GetDataInstance(); data->SetReal(PRIM_SPHERE_RAD, 50); op->Message(MSG_UPDATE); EventAdd();
If you change lready existing objects don't forget to use AddUndo/EndUndo to let the users undo/redo their action.
