On 24/01/2007 at 02:01, xxxxxxxx wrote:
User Information: Cinema 4D Version: R9.5 Platform: Windows ; Language(s) : C++ ;
--------- Hi I've setup a TagPlugin that can be added to different primitives. Now depending on the primitive, i want to change the fieldnames (e.g. static text for a REAL element). How can I do that? "SetString" obviously doesn't work ...
cheers, Juergen
On 24/01/2007 at 02:09, xxxxxxxx wrote:
Also another thing .. can I hide/show elements from within the code?
On 25/01/2007 at 04:41, xxxxxxxx wrote:
Maybe dynamic descriptions could be used for this? The MorphMixer example in the SDK uses dynamic descriptions to change the GUI depending on the scene.
regards /Filip
On 25/01/2007 at 07:02, xxxxxxxx wrote:
Search the forum for "DESC_NAME" and/or "DESC_HIDE". That´s what you need within GetDDescription. There have been other threads in this forum with example code. This should get you going.
On 25/01/2007 at 07:42, xxxxxxxx wrote:
thanks for the hints!
