On 22/01/2007 at 09:24, xxxxxxxx wrote:
User Information: Cinema 4D Version: 9.603 Platform: Windows ; Language(s) : C.O.F.F.E.E ;
--------- Hello, I am not sure if I can clearly explain, what my problem is, but I'll try it anyway I am in the middle of making a non-modal dialog. This dialog should actually only receive data from a expressionplugintag, and - after values are input - store the dialog values back to the plugintag. This sort of works, but strangely not all values are stored correctly in the expressionplugin tag. I can see no pattern, which values are stored and which are not - only that always the same parameters are affected. If another expressionplugintag is involved, completely different parameters are stored or not stored - again with no apparent pattern....? in both plugins (the non-modal dialog and the expressionplugintag) the basecontainer is indexed by an enum variable.... Any ideas, why some values are sent/received correctly and others not? Or, if a basecontainer is not suited for this (approx. 60 parameters) what else can I use to access/store tag data? Sorry for this complicated posting André
On 22/01/2007 at 14:47, xxxxxxxx wrote:
Sorry... Just the good-oldfashioned error 99: change operator. I missed some init-functions, which are a relict, from when the expressionplugintag had a dialog itself.... André
On 24/01/2007 at 14:24, xxxxxxxx wrote:
So it's working now for you?
