On 16/01/2007 at 12:14, xxxxxxxx wrote:
User Information: Cinema 4D Version: R10 Platform: Windows ; Language(s) : C++ ;
--------- Hi everybody, it seems that keyframing I did in previous versions does not work with R10 anymore. Do you have any experience with it? I know, that the timeline/track/sequence things somehow changed. But how can I set keyframes? And: Where can I download SDK for R10. Isn't it ready. Thanks for your help Chris
On 16/01/2007 at 13:56, xxxxxxxx wrote:
Yes, track/sequence/keys are no longer represented by BaseTrack/BaseSequence/BaseKey - they are deprecated. You must now use CTrack/CCurve/CKey, CCurve being automatically added to the track.
The SDK itself is included with R10, but the SDK documentation still isn't ready it seems.
On 16/01/2007 at 23:49, xxxxxxxx wrote:
Thanks for the answer! Has anybody a small samplecode for this?
Chris
On 17/01/2007 at 01:36, xxxxxxxx wrote:
Check out the Morphmixer example in the SDK, especially the static CreateKey function.
On 18/01/2007 at 01:02, xxxxxxxx wrote:
Hello Matthias, have you already used the CreateKey function? I transfered it to my plugin and I can complie, but I don't know, what parameters I have to pass. What is the Index? Is this ID_BASEOBJECT_POSITION for position?
What about the value. It is just a REAL. But a position is a vector.
Before, I used code I found here in the forum. I set it to the end. Thanks Chris if(mybo) { p = mybo->GetPos(); val[0] = p.x; val[1] = p.y; val[2] = p.z; } else return FALSE; for (ii=0; ii<3; ii++) { // check if track exists descID = DescID(DescLevel(ID_BASEOBJECT_POSITION, 0, 0), DescLevel(VECTOR_X+ii, 0, 0)); track = mybo->FindTrack(descID); if (!track) { track = AllocValueTrack(mybo,descID); if (!track) return FALSE; mybo->InsertTrackLast(track); } // check for sequence seq = NULL; for (seq = track->GetFirstSequence(); seq; seq=seq->GetNext()) if (time>=seq->GetT1() && time<=seq->GetT2()) break; if (!seq) { seq = track->AutoAddSequence(mydoc,time); if (!seq) return FALSE; } key = BaseKey::Alloc(seq->GetType()); if (!key) return FALSE; av = GetKeyValue(key); if (!av) return FALSE; av->value = val[ii]; key->SetTime(time); seq->InsertKey(key); }
On 18/01/2007 at 04:18, xxxxxxxx wrote:
Yeah ID_BASEOBJECT_POSITION is the ID for the position. Here is some sample code, it is the modified Morphmixer that records a hidden vector parameter. Remember that there are no sequences anymore and everything is now working with DescIDs.
#include "c4d.h" #include "c4d_symbols.h" #include "omorphmixer.h" class MorphMixerObject : public ObjectData { INSTANCEOF(MorphMixerObject,ObjectData) public: virtual Bool Init(GeListNode* node); virtual Bool Message(GeListNode *node, LONG type, void *data); virtual BaseObject* GetVirtualObjects(PluginObject *op, HierarchyHelp *hh); virtual Bool GetDDescription(GeListNode *node, Description *description,LONG &flags;); static NodeData *Alloc(void) { return gNew MorphMixerObject; } }; static Bool CreateKey(BaseDocument *doc, BaseObject *op, const BaseTime &time;, LONG index, Vector value) { // check if track exists CTrack *trackx = op->FindCTrack(DescID(DescLevel(MORPHMIXER_POSEOFFSET,DTYPE_VECTOR,0),DescLevel(VECTOR_X,DTYPE_REAL,0))); if (!trackx) { trackx = CTrack::Alloc(op,DescID(DescLevel(MORPHMIXER_POSEOFFSET,DTYPE_VECTOR,0),DescLevel(VECTOR_X,DTYPE_REAL,0))); if (!trackx) return FALSE; op->InsertTrackSorted(trackx); } CKey *key = trackx->GetCurve()->AddKey(time); if (!key) return FALSE; key->SetValue(trackx->GetCurve(),value.x); CTrack *tracky = op->FindCTrack(DescID(DescLevel(MORPHMIXER_POSEOFFSET,DTYPE_VECTOR,0),DescLevel(VECTOR_Y,DTYPE_REAL,0))); if (!tracky) { tracky = CTrack::Alloc(op,DescID(DescLevel(MORPHMIXER_POSEOFFSET,DTYPE_VECTOR,0),DescLevel(VECTOR_Y,DTYPE_REAL,0))); if (!tracky) return FALSE; op->InsertTrackSorted(tracky); } key = tracky->GetCurve()->AddKey(time); if (!key) return FALSE; key->SetValue(tracky->GetCurve(),value.y); CTrack *trackz = op->FindCTrack(DescID(DescLevel(MORPHMIXER_POSEOFFSET,DTYPE_VECTOR,0),DescLevel(VECTOR_Z,DTYPE_REAL,0))); if (!trackz) { trackz = CTrack::Alloc(op,DescID(DescLevel(MORPHMIXER_POSEOFFSET,DTYPE_VECTOR,0),DescLevel(VECTOR_Z,DTYPE_REAL,0))); if (!trackz) return FALSE; op->InsertTrackSorted(trackz); } key = trackz->GetCurve()->AddKey(time); if (!key) return FALSE; key->SetValue(trackz->GetCurve(),value.z); return TRUE; } Bool MorphMixerObject::Init(GeListNode *node) { return TRUE; } Bool MorphMixerObject::GetDDescription(GeListNode *node, Description *description,LONG &flags;) { if (!description->LoadDescription(node->GetType())) return FALSE; BaseContainer bc2 = GetCustomDataTypeDefault(DTYPE_VECTOR); bc2.SetBool(DESC_HIDE,TRUE); bc2.SetString(DESC_NAME,"Test"); bc2.SetString(DESC_SHORT_NAME,"Test"); if (!description->SetParameter(DescLevel(MORPHMIXER_POSEOFFSET,DTYPE_VECTOR,0),bc2,DescLevel(ID_OBJECTPROPERTIES))) return FALSE; flags |= DESCFLAGS_DESC_LOADED; return SUPER::GetDDescription(node,description,flags); } Bool MorphMixerObject::Message(GeListNode *node, LONG type, void *data) { switch (type) { case MSG_DESCRIPTION_COMMAND: { DescriptionCommand *dc = (DescriptionCommand* ) data; if (dc->id[0].id==MORPHMIXER_RECORD) { BaseObject *op = (BaseObject* )node; BaseDocument *doc = node->GetDocument(); if (!doc) break; CreateKey(doc,op,doc->GetTime(),MORPHMIXER_POSEOFFSET,Vector(1,2,3)); EventAdd(); } } } return TRUE; } // create morphed object BaseObject *MorphMixerObject::GetVirtualObjects(PluginObject *op, HierarchyHelp *hh) { return NULL; } // be sure to use unique IDs obtained from www.plugincafe.com #define ID_MORPHMIXER_OBJECT 1001156 Bool RegisterMorphMixer(void) { // decide by name if the plugin shall be registered - just for user convenience String name=GeLoadString(IDS_MORPHMIXER); if (!name.Content()) return TRUE; return RegisterObjectPlugin(ID_MORPHMIXER_OBJECT,name,OBJECT_GENERATOR|OBJECT_INPUT,MorphMixerObject::Alloc,"Omorphmixer","morphmixer.tif",0); }
hope that helps
On 18/01/2007 at 05:45, xxxxxxxx wrote:
Yes! Thank you very much!
