On 12/01/2007 at 04:19, xxxxxxxx wrote:
User Information: Cinema 4D Version: 9.507 Platform: Windows ; Language(s) : C++ ;
--------- Hi everyone, i got a description file with some entries and a button. If the user clicks on that button, the description file should be extended by some other values. The Buttons are controlled by
Bool TagCone::Message(GeListNode *node, LONG type, void *data)
and the dynamic description is defined with
Bool TagCone::GetDDescription(GeListNode *node, Description *description, LONG &flags)
Is it possible to call the GetDDescription function from the message function (so that the description file will be extended by the entries defined in the GetDDescription function when i press the button)? if i just try to insert
GetDDescription(node, description, flags);
in the message function i don't know which parameters i have to insert in this function call... Hope somone does understand what i mean ^^
On 14/01/2007 at 14:43, xxxxxxxx wrote:
GetDDescription is called whenever anything happens in the descriptions (AM). There is absolutely no need to call it from the message function.
Instead, use a class member variable that stores what should be added and then use it when GetDDescription is called.
That easy
