On 26/12/2006 at 15:20, xxxxxxxx wrote:
User Information: Cinema 4D Version: 9.6 Platform: Windows ; Language(s) : C++ ;
--------- How can I select some tool? And how to get its container? For example I want to make a command that select the Knife tool and set its Mode to "plane" and Plane to "X-Y".
On 26/12/2006 at 15:59, xxxxxxxx wrote:
Sounds like you'll need to use FindPlugin(ID, C4DPL_TOOL) and then get the BaseContainer using GetDataInstance(), for instance.
The hard part is knowing the ID and getting the specific Attribute Manager/Active Tool settings. These should be stored somewhere in the Resource folder (_api or res or modules possibly).
On 27/12/2006 at 01:40, xxxxxxxx wrote:
Thanks a lot !!!!
On 27/12/2006 at 01:51, xxxxxxxx wrote:
hmmm ... And another question... How can I make some tool active ( display its parameters in AM ) ?
On 27/12/2006 at 06:20, xxxxxxxx wrote:
When the tool is selected, it´s descriptions get display in the AM automatically! Reshowing it, is simply reactivating the tool.
Working on a tool for your edge slide pluggy?
Keep it up.
On 27/12/2006 at 07:54, xxxxxxxx wrote:
"When the tool is selected, it´s descriptions get display in the AM automatically" But how to select it? By C++. ... Actually I put aside MultiSlide, and make another plug.
On 27/12/2006 at 08:00, xxxxxxxx wrote:
The user selects it. Or do you need this for something different? Maybe it would be better to explain why you want to select a tool yourself?
Anyway, select a tool by this: doc->SetAction(PLUGINID_OF_TOOLPLUGIN);
If this doesn´t work, try a GeSyncMessage(EVMSG_TOOLCHANGED); //or another message type
So, what plug are you workin on?
Hope that helps Samir
On 27/12/2006 at 08:19, xxxxxxxx wrote:
It is for some commands I need to have, and I want to write it on c++ not on COFFEE And for one tool ... it is long to explain, you will see it Thank you very much ! It is just I looked for !
On 27/12/2006 at 08:34, xxxxxxxx wrote:
xarashoa
