On 11/12/2006 at 04:05, xxxxxxxx wrote:
User Information: Cinema 4D Version: 9.6 Platform: Language(s) : C.O.F.F.E.E ;
--------- Hello! I've got a question: I've got the following code:
var file = new(Filename); file=GeGetRootFilename(); file->RemoveLast(); file->AddLast("objekt.c4d"); LoadDocument(file); var currentObject = GetActiveObject(doc); var clone; clone=currentObject->GetClone(CL_NO_HIERARCHY); var actdoc=GetActiveDocument(); actdoc->InsertObject(clone,NULL,NULL); //KillDocument(); EventAdd(DOCUMENT_CHANGED);
I would like to load "objekt.c4d" into my actual scene. But in this case cinema opens a new scene called "objekt.c4d". That's not what I want. Cinema should insert the object from "objekt.c4d" to my actual scene, and not open a new one. Shouldn't it work with "KillDocument();". I cannot find the function in SDK 9.5. Could anybody helf me? Thanks a lot!
On 11/12/2006 at 06:42, xxxxxxxx wrote:
Afaik! not possible in COFFEE. Sorry, only via C++.
On 11/12/2006 at 06:44, xxxxxxxx wrote:
As a workaround I would suggest this.
1. Load the document 2. Copy the objects and materials 3. Insert them into your already opened scene 4. Close the loaded document
There doesn´t seem to be another way imo.
On 11/12/2006 at 06:45, xxxxxxxx wrote:
You would have to copy-paste the object from the document opened with LoadDocument. You can step through open documents with GetNext/GetPrev. It's not actually fun to do with COFFEE, the C++ API is much easier to use in this regard.
