On 07/12/2006 at 02:49, xxxxxxxx wrote:
User Information: Cinema 4D Version: Platform: Mac ; Language(s) : C.O.F.F.E.E ;
--------- when my coffee tag code is executed: how do i get my own BaseTag (myself) ?
if the tagged object has only 1 coffee tag the code below works, but there should be a better solution for this !! any help !?
var tag = op->GetFirstTag(); while(tag) { if(tag->GetType()==5675) { break; } // 5675 = Coffee tag tag=tag->GetNext(); }
On 07/12/2006 at 03:48, xxxxxxxx wrote:
If you want to hit a specific coffe tag you can name them differently and add the name for searching. But if you need more than one tag, I'd say it's much better to get a ID at PluginCafe and have your own unique ID to search for. You would then use coffe expression tag plugins instead. There is a included "empty" frame work in the SDK documentation with notes for each part what to fill in to make it run.
Lennart
