On 06/12/2006 at 09:48, xxxxxxxx wrote:
User Information: Cinema 4D Version: Platform: Mac ; Language(s) : C.O.F.F.E.E ; XPRESSO ;
--------- hi,
Is it possible to find the active camera in coffee or xpresso ?
i'd like to make a coffee or xpresso tag to set the visible_in_render button according to the active camera.
-> a lot of possibilities !!!
if for example i have 5 cameras in an architectural scene i could have 5 lightning sets which automatically switch on/off when i change the camera! the same for compostiting backgrounds (like sky on a plane) or object groups which are not visible and mustnt slow down the renderer. etx
On 06/12/2006 at 14:55, xxxxxxxx wrote:
Hi Zeorge,
In COFFEE, you can use:
var cam = doc->GetRenderBaseDraw()#BASEDRAW_DATA_CAMERA;
I'm not sure if there's a way to do it in Xpresso, other than a COFFEE node with the code above.
HTH
Rick
