Break Rendering
On 02/12/2006 at 16:33, xxxxxxxx wrote:
Cinema 4D Version:
Platform:
Language(s) :---------
Hi all,when i'm in rendering in viewport, c4d can stop the render if i touch the interface... not only if i press esc.
How i can detect when C4D stop the rendering?
Any message ?Cheers
Renato
On 04/12/2006 at 05:00, xxxxxxxx wrote:
MSG_MULTI_RENDERNOTIFICATION
if(!data.start) render_aborted
On 04/12/2006 at 07:32, xxxxxxxx wrote:
Close, but 'data' is a void*, so do this:
if (type == MSG_MULTI_RENDERNOTIFICATION)
if (!data) return TRUE;
RenderNotificationData* rnd = (RenderNotificationData* )data;
// Render End
if (!rnd->start) //render_aborted
...This is not available before R8.5.
On 04/12/2006 at 09:06, xxxxxxxx wrote:
I assumed he knew how to retrieve the data.
On 04/12/2006 at 09:55, xxxxxxxx wrote:
Thanks, i'll try this MSG_MULTI_RENDERNOTIFICATION :)
For now i got a good help from Chris, so i checked vd->testBreak after each bucket and work good.
Renato T.
On 04/12/2006 at 12:50, xxxxxxxx wrote:
Just in case. :)
On 04/12/2006 at 13:01, xxxxxxxx wrote:
true that :)
On 04/12/2006 at 22:19, xxxxxxxx wrote:
