On 30/11/2006 at 03:05, xxxxxxxx wrote:
User Information: Cinema 4D Version: Platform: Mac ; Language(s) : C.O.F.F.E.E ;
--------- maybe a simple one, but i didnt get it...
i can get the active obj with obj=doc->GetActiveObject();
but what if i select more than one object. obj=doc->GetActiveObject(); seems to return nil then !
...? any inputs ?
On 30/11/2006 at 04:50, xxxxxxxx wrote:
You then first need to loop the document, searching for the active ones. If you do a search for "hierarchy" here at SDK you'll find example code, including finding specific tags as well.
Cheers Lennart
On 30/11/2006 at 18:13, xxxxxxxx wrote:
Hi zeorge ...
I used to do it like below ...
AtomArray *atm=AtomArray::Alloc(); BaseDocument *doc=GetActiveDocument(); doc->GetActiveObjects(*atm,FALSE); LONG lObjCnt=atm->GetCount();//Taking the selected object count ... MessageDialog(LongToString(lObjCnt) + " objects are selected!"); //If you want to take the first object BaseObject *obj=(BaseObject* )atm->GetIndex(0); MessageDialog("The first object is " + obj->GetName());
I hope the above code block can help you ... Take care the function is GetActiveOjbect s not GetActiveObject ...
Wishing you all the best ... Zaw Min Tun
On 30/11/2006 at 18:46, xxxxxxxx wrote:
Sorry ... You're talking about Coffee ...
I found a forum link here ... http://forums.cgsociety.org/showpost.php?p=2776293&postcount;=4
On 06/12/2006 at 04:17, xxxxxxxx wrote:
OK, I GOT THE SOLUTION NOW BY MYSELF .... AND SHARE IT HERE FOR OTHERS :
this code counts the active objects...
var obj=GetActiveDocument()->GetFirstObject(), active_objects; if(obj->GetBit(BIT_AOBJ)) { active_objects=0; } else { active_objects=-1; } while(obj) { active_objects++; obj=obj->SearchNext(BIT_AOBJ); } println(active_objects, " active objects");
