On 28/11/2006 at 05:45, xxxxxxxx wrote:
User Information: Cinema 4D Version: 9.5-10 Platform: Windows ; Mac OSX ; Language(s) : C++ ;
--------- Hi,
it's a simple and basic question, but I can't find a solution. I have the following class (don't ask, why I use my own Vector class, it's part of a physical simulation code, that I want to use as a black box) :
class Vector3 { public: union { struct { float x, y, z; }; float m[3]; }; Vector3() { } // blank constructor Vector3(float x, float y, float z); // constructor with 3 values void add(Vector3 & A); ... // further methods... };
The problem is, that I get compiler errors with CodeWarrior in the lines, where I try to access the values with Vector3 v.x:
Error: undefined identifier 'x'...
With VC6 everything is fine!? Any tips?
Thank you.
On 28/11/2006 at 07:00, xxxxxxxx wrote:
Ok, I fixed it with a dirty hack. What do you mean?
class Vector3 { public: float x, y, z; float *m; Vector3() {m = &x;} // blank constructor Vector3(float x, float y, float z); // constructor with 3 values void add(Vector3 & A); ... // further methods... }; Vector3::Vector3(float x, float y, float z) { this->x = x; this->y = y; this->z = z; this->m = &this-;>x; };
On 28/11/2006 at 08:18, xxxxxxxx wrote:
Hmm, I am not sure where the exact problem is or what you actually wanna do. However, I´d use the initialisation list. And &this-;>x is also unnecessary imo as it´s simply x. Also why is m a pointer? no need imo
Vector3::Vector3(float sx, float sy, float sz) : x(sx),y(sy),z(sz),m(sx) {}
On 28/11/2006 at 09:24, xxxxxxxx wrote:
Some parts of the code access the vector members with myVector.x, myVector.y... and some parts with myVector.m[0..2]. So this is the reason for the use of the union. But if you use a union, you have to struct x, y, z in order to get aligned to the same memory address as the m[3] array. My hack is to make these different accesses possible, since the noname struct causes the compiler errors.
I'm not very familiar with initialisation list. Does your suggestion really do the task, I just described? It doesn't seem, that m is accessable as an array.
On 28/11/2006 at 09:41, xxxxxxxx wrote:
Ah. don´t know why your compiler gives an error. Have you tried naming the struct and accessing it via myVector.structName.x ? That´s how I´d have done it.
The initialisation list is always prefered as it sometimes can save unnecessary constructor calls when initialising within the constructor body. So I am using them a lot.
That would be possible of course. But I told about treating the code module as a black box. I would have to adjust a huge of code files and there are other classes with the same problem...
But thanks for looking and thinking.
