On 24/11/2006 at 19:55, xxxxxxxx wrote:
User Information: Cinema 4D Version: 9 Platform: Windows ; Language(s) : C++ ;
--------- Hi ...
In a dialog plugin ... Can I know the current position of my dialog? How can I know it? Can I change the position then?
Looking forward to hear from you ... and thanks in advance ... Zaw Min Tun
On 26/11/2006 at 20:54, xxxxxxxx wrote:
Not possible as far as I know. There is no such functionality. As you probably know, you can open the dialog either at a specific screen position (or with respect to the cursor using (-1,-1)). There are no functions to change or get the position thereafter.
Now, when I was opening a dialog over the View window to show object names, I used a clever but dangerous trick where I'd open the dialog, do some calculations with respect to the View window to get a new position, and then close and reopen the dialog at that new position. It is not a recommended solution and was abandoned due to instabilities.
Such is the control of Cinema 4D SDK GUIs.
On 28/11/2006 at 18:37, xxxxxxxx wrote:
Thank you ... Robert ...
Best regards ... Zaw Min Tun
