On 24/11/2006 at 04:34, xxxxxxxx wrote:
User Information: Cinema 4D Version: R9.507 Platform: Windows ; Language(s) : C++ ;
--------- Hi i have got just a little layout problem. I have a description file with some vectors. They are shown as column vectors. Is there a way to show them as row vectors? Thx
On 24/11/2006 at 18:11, xxxxxxxx wrote:
Can I take a look at your code sample?
Zaw Min Tun
On 28/11/2006 at 00:03, xxxxxxxx wrote:
GROUP COM_GROUP { DEFAULT 1; VECTOR COM {UNIT METER; STEP 0.1; CUSTOMGUI SUBDESCRIPTION;} }
On 28/11/2006 at 01:07, xxxxxxxx wrote:
The Vector 'customgui' (which is used for all vectors either in dialogs, the Attributes Manager, or elsewhere) only shows vectors as row vectors. As far as I know, there is no way to change it.
For a dialog, you could set up a set of three gadgets, one for each vector component, and then set them according to the vector component values. You don't get the convenience of GetVector() - you have to use GetReal() for each component gadget.
For a customgui like in the Attributes Manager, you could do the same thing, but you'd have to do this instead:
GROUP COM_GROUP { DEFAULT 1; REAL COM_X {...} REAL COM_Y {...} REAL COM_Z {...} }
On 28/11/2006 at 04:38, xxxxxxxx wrote:
Ok thanks, thats the same way i tried to avoid the standart notation of vectors
