Material::CopyTo() problems
On 16/11/2006 at 13:28, xxxxxxxx wrote:
Cinema 4D Version: 8.2-10.0
What is wrong with this code? I've tried without COPY_NO_INTERNALS, but the links to the Texture tags are then broken. I've tried calling AliasTrans::Translate after each and at the end (as shown). Is the AliasTrans::Init() document correct (source)? This is getting frustrating as it works to an extent, but the materials don't update properly (show the texture image) and rendering fails.// Paste Materials //*---------------------------------------------------------------------------* Bool GeIPPPaste_Materials(BaseDocument* sdoc, BaseObject* sobj, BaseDocument* ddoc, BaseObject* dobj) //*---------------------------------------------------------------------------* { BaseTag* stag; BaseTag* dtag; TextureTag* sttag; TextureTag* dttag; Material* smat; Material* dmat; GeData data; String sname; BOOL doTranslate = FALSE; AutoAlloc<AliasTrans> aliastrans; if (!(aliastrans && aliastrans->Init(sdoc))) return FALSE; // Materials for (stag = sobj->GetFirstTag(); stag; stag = stag->GetNext()) { if (!stag->IsInstanceOf(Ttexture)) continue; sttag = (TextureTag* )stag; sttag->GetParameter(DescID(TEXTURETAG_MATERIAL), data, NULL); smat = static_cast<Material*>(data.GetLink(sdoc, Mbase)); if (!smat) continue; sname = stag->GetName(); for (dtag = dobj->GetFirstTag(); dtag; dtag = dtag->GetNext()) { if (!dtag->IsInstanceOf(Ttexture)) continue; dttag = (TextureTag* )dtag; dttag->GetParameter(DescID(TEXTURETAG_MATERIAL), data, NULL); dmat = static_cast<Material*>(data.GetLink(ddoc, Mbase)); if (!dmat) continue; if (dtag->GetName() != sname) continue; // Found matching materials, copy if (!smat->CopyTo(dmat, COPY_NO_INTERNALS, aliastrans)) continue; //aliastrans->Translate(TRUE); dmat->Update(TRUE, TRUE); dmat->Message(MSG_CHANGE); doTranslate = TRUE; break; } } if (doTranslate) aliastrans->Translate(TRUE); return TRUE; }
Thanks,
On 16/11/2006 at 15:03, xxxxxxxx wrote:
Okay, this code is mostly working, but I still have to either render or Material Manager->Apply to get the material changes to show in the View.
How do I do that, please?
// Paste Materials //*---------------------------------------------------------------------------* Bool GeIPPPaste_Materials(BaseDocument* sdoc, BaseObject* sobj, BaseDocument* ddoc, BaseObject* dobj) //*---------------------------------------------------------------------------* { AutoAlloc<AliasTrans> aliastrans; AutoAlloc<AtomArray> matArray; AutoAlloc<AtomArray> tagArray; if (!(matArray && tagArray && aliastrans && aliastrans->Init(sdoc))) return FALSE; BaseTag* stag; BaseTag* dtag; TextureTag* sttag; TextureTag* dttag; Material* smat; Material* dmat; GeData data; String sname; // Materials for (stag = sobj->GetFirstTag(); stag; stag = stag->GetNext()) { if (!stag->IsInstanceOf(Ttexture)) continue; sttag = (TextureTag* )stag; sttag->GetParameter(DescID(TEXTURETAG_MATERIAL), data, NULL); smat = static_cast<Material*>(data.GetLink(sdoc, Mbase)); if (!smat) continue; sname = stag->GetName(); for (dtag = dobj->GetFirstTag(); dtag; dtag = dtag->GetNext()) { if (!dtag->IsInstanceOf(Ttexture)) continue; dttag = (TextureTag* )dtag; dttag->GetParameter(DescID(TEXTURETAG_MATERIAL), data, NULL); dmat = static_cast<Material*>(data.GetLink(ddoc, Mbase)); if (!dmat) continue; if (dtag->GetName() != sname) continue; // Found matching materials, copy if (!smat->CopyTo(dmat, COPY_NO_BITS, aliastrans)) continue; matArray->Append(dmat); tagArray->Append(dttag); break; } } LONG count = matArray->GetCount(); if (count) { aliastrans->Translate(TRUE); for (LONG i = 0; i < count; i++) { dmat = static_cast<Material*>(matArray->GetIndex(i)); dttag = static_cast<TextureTag*>(tagArray->GetIndex(i)); dttag->SetMaterial(dmat); dmat->Update(TRUE, TRUE); dmat->Message(MSG_CHANGE); dttag->Message(MSG_UPDATE); } } return TRUE; }
Thanks,
On 16/11/2006 at 15:29, xxxxxxxx wrote:
Seems that I needed this as well:
.... aliastrans->Translate(TRUE); for (LONG i = 0; i < count; i++) { dmat = static_cast<Material*>(matArray->GetIndex(i)); dttag = static_cast<TextureTag*>(tagArray->GetIndex(i)); dttag->SetMaterial(dmat); dmat->Update(TRUE, TRUE); dmat->Message(MSG_CHANGE); dttag->Message(MSG_UPDATE); dobj->Message(MSG_UPDATE); } ...
Thanks for the conversation! ;)
On 18/11/2006 at 08:09, xxxxxxxx wrote:
lol, you are too fast in finding your own bugs. ;-)
On 18/11/2006 at 10:01, xxxxxxxx wrote:
The worst part is that there is no example of using CopyTo() with Materials. They neglect the little bit about needing to relink them in the Texture tag and I still don't know why the Object needs to be updated - but heck, it works. ;)
