On 25/10/2006 at 08:23, xxxxxxxx wrote:
User Information: Cinema 4D Version: 9.6 Platform: Windows ; Language(s) : C++ ;
--------- Is it possible to retrieve the texture *filename* applied to a material's basechannel? (i.e. the filename of the texture applied in the color channel)
thanks!
On 25/10/2006 at 09:42, xxxxxxxx wrote:
Yes:
// Get Color Channel BaseChannel* bchan = mat->GetChannel(CHANNEL_COLOR); if (!bchan) continue; // Extract full image file path Filename suggestedFolder = bchan->GetData().GetFilename(BASECHANNEL_SUGGESTEDFOLDER); String map = bchan->GetData().GetString(BASECHANNEL_TEXTURE); Filename fullpath = suggestedFolder + Filename(map);
On 25/10/2006 at 09:51, xxxxxxxx wrote:
works perfectly thanks!
On 26/10/2006 at 01:52, xxxxxxxx wrote:
hmm, i've found out that my current code:
** // Extract full image file path String map = pChannel- >GetData().GetString(BASECHANNEL_TEXTURE); if (map.GetLength() == 0) return FALSE;
Filename suggestedFolder = pChannel->GetData().GetFilename(BASECHANNEL_SUGGESTEDFOLDER); if (suggestedFolder.GetString().GetLength() == 0) // same as the document suggestedFolder = pDoc->GetDocumentPath();
Filename fullpath = suggestedFolder + Filename(map); **
fails to retrieve the right path when the map is located within a subfolder of the main scene location (i.e. on c4d samples, textures are usually located in a 'tex' subfolder).
This code nevertheless is working fine:
** Filename path; GenerateTexturePath(pDoc- >GetDocumentPath(), Filename(pChannel->GetData().GetString(BASECHANNEL_TEXTURE)), Filename(), &path;) **
cheers
On 26/10/2006 at 04:33, xxxxxxxx wrote:
I clear the suggestedFolder when the texture is made local (wrt the c4d document). When the texture is elsewhere, suggestedFolder has the path to the texture. Should have mentioned that - sorry. :S
