Break Render
    On 11/10/2006 at 21:10, xxxxxxxx wrote:
    Cinema 4D Version:   9.0
    Platform:   Windows  ;
    Hi ...
    Now I render my document using the statement below ...
    RenderDocument(doc, bc,MyProgressHook,pd, bmOutput,RENDERFLAG_EXTERNAL,NULL);
    It's working like "Render To PictureViewer"
    It's working ... but if the user want to break the render using Ctrl+Break ... it's not responding ...
    I read the threads about breaking render ...
    I try to use TestBreak ... but it's not working ...
    Please anybody can tell me in detail ...? ;-)
    Thanks in advance ...
    Zaw Min Tun
    On 11/10/2006 at 23:27, xxxxxxxx wrote:
    i think you have to give it a Thread in stead of NULL.
    The thread is waiting for the testbreak and should then stop the rendering
    On 16/10/2006 at 20:41, xxxxxxxx wrote:
    But I don't know how I can make it ...
    Can you show me some code sample?
    But I'll try it again ...
    Anyway ... I really thank you ...
    Zaw Min Tun
    On 16/10/2006 at 21:00, xxxxxxxx wrote:
    Take a look at the section of code where RenderDocument() is called in simplematerial.cpp and particlevolume.cpp in the plugins:cinema4dsdk folder. There you see how they get the thread.
    On 16/10/2006 at 21:25, xxxxxxxx wrote:
    Then I take a look at them ...
    I pray they can really help me ... ;-)
    I've already spent nearly 5 days on this ...
    Zaw Min Tun
    ありがとう ... 本当に ...
    On 16/10/2006 at 21:56, xxxxxxxx wrote:
    My plugin is a dialog plugin ...
    When the user presses a button ... The user will see the Picture Viewer rendering ...
    When redering is done the user will get a bitmap file ...
    But while rendering ... the user cannot have a break on that render ... bcos I render like this ...
    Some old threads told me to use TestBreak() ...
    For that I create a class called myThread ...
    class myThread:public Thread
    public:
         myThread();
         virtual void Main(void);
    myThread::myThread()
    void myThread::Main(void)
    Then when I call RenderDocument() ...
    myThread *thdRender=new myThread;
    RenderDocument(doc, bc,MyProgressHook,pd, bmOutput,RENDERFLAG_EXTERNAL,thdRender->Get());
    If I did like above ... the code that I wrote in MyProgressHook was not running ...
    And if I insert the line thdRender->TestBreak() ... it's not still working ...
    But I'd go on ... ;-)
    Zaw Min Tun ...
    On 16/10/2006 at 22:37, xxxxxxxx wrote:
    If you want to use your own thread to test for breaks, make sure that it is running!
    You're going to need to call thdRender->Start() before calling RenderDocument() and End() afterwards. You will also need to implement myThread::TestDBreak() unless you want a deadlock situation.
    Try something like this and see if it works:
    public:
         myThread();
         virtual Bool TestDBreak();
    // This tests for the Esc key to break the thread
    Bool myThread::TestDBreak()
         BaseContainer     keyinput;
         return (GetInputEvent(BFM_INPUT_KEYBOARD, keyinput) && (keyinput.GetLong(BFM_INPUT_CHANNEL) == KEY_ESC));
    if (!thdRender->Start(TRUE)) // Error starting thread
    thdRender->End();
    On 17/10/2006 at 20:12, xxxxxxxx wrote:
    Really thank you again ...
    Now I try to check if ESC is pressed ( in ProgressHook ) ... and it's OK ... The plugin knows when ESC is pressed ... But I don't know how to stop the rendering ...
    I forgot to tell that I'm still using NULL as the last parameter instead of thdRender->Get() ... bcos' if I didn't use NULL ... the code I'm writing in ProgressHook is not working ...
    In ProgressHook I call the ShowBitmap with the current bitmap ... So it's changing all the time while rendering ...
    So I'm a bit lost ...
    But Robert ... you answers helped a lot ...
    And I hope you will go on ... ;-)
    Zaw Min Tun
    On 18/10/2006 at 02:13, xxxxxxxx wrote:
    Hmmm, the way the documentation reads, RenderDocument() should be using the passed Thread as a sort of 'overlord' to test for a user break. This should stop the render automatically - theoretically and assuming these points.
    One question though: Are you using a clone of the BaseDocument!!? As the docs state: Must be a clone of the real document! This might have an impact.
    On 19/10/2006 at 00:10, xxxxxxxx wrote:
    Yeah ...
    When I use the clone doc ... the way it's working really changed ... I can use ESC to stop rendering ...
    But after stopping the render ... C4D also stop responding ... When the ESC is pressed ... I ended the thread ...
    What more do I need to do?
    But I think I can move a new step ... ;-)
    Thank you a lot ...
    Zaw Min Tun
    On 19/10/2006 at 01:12, xxxxxxxx wrote:
    Hello ... Robert ...
    I came here to let you know that now it's working ... and to say thank you ...
    Thank you ... a lot ...
    May god bless each and every one ...
    Zaw Min Tun
