On 11/10/2006 at 03:41, xxxxxxxx wrote:
User Information: Cinema 4D Version: R9.603 Platform: Language(s) : C.O.F.F.E.E ;
--------- Is it possible to read value of Y from a USERDATA-Spline with a Coffee-Tag from the userdatas of the object that contain the tag. Other Userdatafields like object link or real value fields are no problems with: var spline = op#ID_userdata:4; But when I try to get the Userdata-Spline there is a error: "Parameter value is not accessible (object unknown)" Is there no way ?
On 11/10/2006 at 06:30, xxxxxxxx wrote:
nope, not possible. The Spline graph class is not accessible via COFFEE.
On 11/10/2006 at 14:25, xxxxxxxx wrote:
Oh, sh*t ! What do you think about xpresso with Coffee node solutions ? I think is only a half solution. But I think I must make it with XPresso/Coffe-Node mix Thank you for answer !
