On 02/09/2006 at 13:50, xxxxxxxx wrote:
User Information: Cinema 4D Version: 9.6 Platform: Windows ; Language(s) : C.O.F.F.E.E ; XPRESSO ;
--------- Ti to All, I write a script to switch on-off some bool gadgets in the render settings panel (I would like to insert to xpresso COFFE node finally). I get the active render settings and that container datas what I would like to change. but after using the SetData function doesnt occured anything. Can I control render settings panel from script or xpresso COFFE node? Should I refresh something? I copy here the whole script what I created:
main(doc, op) { var rd=doc->GetFirstRenderData(); var activeRD; var rdName; var rdBit; // active render setting selection while (rd) { rdName = rd->GetName(); rdBit = rd->GetBit(BIT_ARDATA); if (rdBit == 1) break; rd = rd->GetNext(); } // select switches from bc println("NAME OF ACTUAL RENDER SETTINGS = " + tostring(rd->GetName())); var bc = rd->GetContainer(); //println(bc->GetData(RDATA_RESOLUTION)); println("- actual posteffect switch = " + tostring(bc->GetData(RDATA_POSTEFFECTS_ENABLE))); println("- actual autolight switch = " + tostring(bc->GetData(RDATA_AUTOLIGHT))); // switch off selected option gadgets in bc var result = bc->SetData(RDATA_POSTEFFECTS_ENABLE,FALSE); var result = bc->SetData(RDATA_AUTOLIGHT,FALSE); // audit the changed parameters println("- set posteffect switch = " + tostring(bc->GetData(RDATA_POSTEFFECTS_ENABLE))); println("- set autolight switch = " + tostring(bc->GetData(RDATA_AUTOLIGHT))); }
any suggestion would be cool thanks, fuxy
On 05/09/2006 at 04:36, xxxxxxxx wrote:
Hi all, any idea what is wrong? regards, Zoltan
On 05/09/2006 at 07:19, xxxxxxxx wrote:
Hy fuxi, it is just an idea I did not try this out yet, but perhaps sending some message might help? I 'd try doc->Message(DOCUMENT_CHANGED) for example or perhaps something with MSG_UPDATE? Like said, just an idea I do not know if it helps but I hope so. Good luck, Ebiwahnkenobi
On 05/09/2006 at 09:49, xxxxxxxx wrote:
Hi fuxy ,
I think you have to set the container after setting it's data
rd->SetContainer(bc);
Ciao , Frank.
On 05/09/2006 at 10:39, xxxxxxxx wrote:
Hi Frank you won :)) . Thank you very much!!! Regards, fuxy
On 05/09/2006 at 15:27, xxxxxxxx wrote:
Hi ebiwahnkenobi, you won too, I had to use EventAdd() function... thanks again Regards, fuxy
