C4D R8.206 SDK == BodyPaint R???
On 01/09/2006 at 02:45, xxxxxxxx wrote:
Cinema 4D Version: 8.2+
Platform: Windows ;
The title has my question - if I'm compiling my plugin with the 8.206 SDK, what would be the lowest compatible version of BodyPaint?
BP 2.0? 2.5? (I'm not even sure what the available version numbers are :).
Thanks,
Keith
On 01/09/2006 at 06:51, xxxxxxxx wrote:
You can check the general version number of the BodyPaint module available using GeGetVersionType() to see if VERSION_BODYPAINT or VERSION_BODYPAINT2 is running. I don't see a way to get the actual version number. You may need to use GeGetSerialInfo(SERIAL_BODYPAINT,&sni;) and try to make the determination from the BodyPaint serial number (shrug).
On 01/09/2006 at 11:33, xxxxxxxx wrote:
Thanks Robert, but what I'm really trying to determine is...
If I'm using the 8.206 SDK, what is the lowest version of BodyPaint that will work with my plugin?
I guess it depends on when version 2 (and/or version 2.5) was released, relative to C4D versions.
I'm getting ready to release my new BodyPaint plugin set and am trying to fill out the "Requirements" section of the docs - I don't know which (Stand alone) version of BodyPaint is required.
On 01/09/2006 at 11:57, xxxxxxxx wrote:
Ah. I think that BodyPaint3D needed to be upgraded to v2.0 when R8.0 was released. v2.5 was either R9.0 or R9.5.
On 01/09/2006 at 12:01, xxxxxxxx wrote:
...I seem to have a "BodyPaint Release 2" here on my machine, and in the start-up banner, it says:
BodyPaint 3D V8.206
...in the bottom-left corner, so I guess that links C4D R8.206 with BP R2 but I don't have a serial number for that version, so I can't test my plugin with it.
Do you have a working version of Stand alone BodyPaint R2 (or C4D R8.206 + BP R2) to test my plugin? (I think a demo version would work)
On 01/09/2006 at 13:14, xxxxxxxx wrote:
I don't have the standalone version. I have BP installed in R8.503 and above. Maybe you have the remnants of a demo install on your R8.206?
If it were installed, I might take you up on the test offer. But, as you can see by my recent posts here, I'm deep in .... trying to get a tool worked out for interPoser Pro. :)
BP v2.5 was definitely R9.5 (as noted on the MAXON Shop).
BP v2.0 may have been R8.5 as I've found a reference to R8.2 and BP v1.1:
On 01/09/2006 at 13:31, xxxxxxxx wrote:
Thanks for that link/info. Hmmm.. that press release kinda makes me think that BP v1.1 might support R8.206 plugins.
I really want to get this plugin out, but it looks like I'll have to wait for some sort of official answer to this.
On 02/09/2006 at 07:53, xxxxxxxx wrote:
Good question. I don't have any old BP standalone installations either, but I've asked the developers if they have a clue.
On 02/09/2006 at 10:00, xxxxxxxx wrote:
Thanks... I'll wait as patiently as possible :).
On 14/09/2006 at 11:05, xxxxxxxx wrote:
BP2 is R8.2 (8.2 plugins won't work with BP1). BP2.5 is R9.5.
