BaseContainer Performance
On 29/08/2006 at 07:47, xxxxxxxx wrote:
Cinema 4D Version:   9.6
Platform:   Windows  ; Mac  ;
I have a general question concerning getting values out of a BaseContainer instance.
I need some values from my plugin object several times in a calculation, so I am asking myself if it´s faster to store the value from the basecontainer in a variable of mine and use this one or if it´s performance-wise the same if I´d retrieve the values directly from the basecontainer?
I assume the former is the case but I am not absolutely sure.
Thanks
Katachi
On 29/08/2006 at 09:50, xxxxxxxx wrote:
Most definitely faster to use a variable to store the BaseContainer value if you are going to use it more than once. This will be slow if done multiple times:
x = m * obj->GetDataInstance()->GetReal(ID_MYREAL);
y = n * obj->GetDataInstance()->GetReal(ID_MYREAL);
z = o * obj->GetDataInstance()->GetReal(ID_MYREAL);
This won't be quite as slow:
BaseContainer* bc = obj->GetDataInstance();
x = m * bc->GetReal(ID_MYREAL);
y = n * bc->GetReal(ID_MYREAL);
z = o * bc->GetReal(ID_MYREAL);
But this is better:
r = bc->GetReal(ID_MYREAL);
x = m * r;
y = n * r;
z = o * r;
Of course, you should weigh how many times you'll need to reference the BaseContainer to set or get values as well as how often the values are needed. For a one-off use, the quickest method would be (and avoid the stack variables) :
On 29/08/2006 at 10:01, xxxxxxxx wrote:
Hi Kuro,
thanks, that confirms what I am currently doing. Thanks for the check! 🙂
