On 20/08/2006 at 03:35, xxxxxxxx wrote:
User Information: Cinema 4D Version: 8.2+ Platform: Windows ; Language(s) : C++ ;
--------- It looks like the UNDO_ types changed at some point after R7.3, so I just wanted to get some clarification on what to use and where. In the 7.3 ge_prepass.h file, I see these:
#define UNDO_OBJECT_REC 1 #define UNDO_OBJECT 2 #define UNDO_OBJECT_DATA_REC 3 #define UNDO_OBJECT_DATA 4 #define UNDO_MATERIAL_DATA 5 #define UNDO_TAG_DATA 6 #define UNDO_KEY_DATA 7 #define UNDO_SEQUENCE_DATA 8 #define UNDO_TRACK_DATA 9 #define UNDO_OBJECT_NEW 10 #define UNDO_TAG_NEW 11 #define UNDO_KEY_NEW 12 #define UNDO_SEQUENCE_NEW 13 #define UNDO_TRACK_NEW 14 #define UNDO_MATERIAL_NEW 15 #define UNDO_OBJECT_DEL 17 #define UNDO_TAG_DEL 18 #define UNDO_KEY_DEL 19 #define UNDO_SEQUENCE_DEL 20 #define UNDO_TRACK_DEL 21 #define UNDO_MATERIAL_DEL 22 #define UNDO_OBJECT_ACTIVE 23
...and in the R8.206 (and later) SDK ge_prepass.h file, I see these:
#define UNDO_CHANGE 40 #define UNDO_CHANGE_NOCHILDS 41 #define UNDO_CHANGE_SMALL 42 #define UNDO_CHANGE_SELECTION 43 #define UNDO_NEW 44 #define UNDO_DELETE 45 #define UNDO_ACTIVATE 46 #define UNDO_DEACTIVATE 47 #define UNDO_TLACTIVATE 48 #define UNDO_TLDEACTIVATE 49
...but I don't see the first group listed in the later files or the second group listed in the 7.3 file, so I assume the second (smaller) set of UNDO_ types replace the earlier ones? Specifically, I'm mostly 'changing' the BaseSelect returned from op->GetPolygonS() and op->GetPointS()... so I'd use:
BaseSelect *pSel = op->GetPolygonS(); m_baseDoc->StartUndo(); if( pSel->GetCount() == 0 ) { m_baseDoc->AddUndo(UNDO_CHANGE_SELECTION, pSel); m_pUserSelected->SelectAll(0, op->GetPolygonCount()-1); // select all } do_other_stuff(); m_baseDoc->EndUndo();
...? My question in this case is related to the fact that I'm not really changing a 'Selection Tag' that's attached to the object, I'm making changes directly to the object's current selection. Would I still use UNDO_CHANGE_SELECTION there? Also, if I'm making changes to the UVW tag on an object, do I use UNDO_CHANGE? Thanks, Keith
On 20/08/2006 at 03:39, xxxxxxxx wrote:
...actually, I'm guessing that I should be using AddUndo(UNDO_CHANGE, op) for changes to the BaseSelect returned by op->GetPolygonS()... right?
On 20/08/2006 at 04:18, xxxxxxxx wrote:
Hey Keith,
Yes. UNDO_CHANGE_SELECTION is only for Editor selections. UNDO_CHANGE will store an undo for an object, including substructures - i.e.: tags. Nonetheless, best to verify that the undo covers the change of the tag's BaseSelect.
