Strange Crash Problem
On 11/08/2006 at 10:42, xxxxxxxx wrote:
Cinema 4D Version:   9.603
Platform:   Windows  ;
Hi all
i try to make a copy paste system for polygons.
And i'm having some stability problems.
Here is the code of the "copy" part. Sorry, i couln't simplify it anymore so that it still crashes.
#include "c4d.h"
#include "c4d_symbols.h"
struct Clipboard
~Clipboard() { TakeObjects(NULL); }
AutoAlloc<AtomArray> array;
void TakeObjects( AtomArray* a );
void Clipboard::TakeObjects( AtomArray* a )
if( !array ) return;
// free all stored objects
array->FilterObjectChildren();
for( LONG i=0; i<array->GetCount(); ++i )
    BaseObject* op = static_cast<BaseObject*>( array->GetIndex(i) );
    BaseObject::Free( op );
array->Flush();
GeAssert( array->GetCount()==0 );
// copy pointers from a to array
if( a ) a->CopyTo( array );
static Clipboard *g_clip = NULL;
void FreeClipboard()
gDelete( g_clip );
Clipboard* GetClipboard()
if( !g_clip ) {
    g_clip = gNew Clipboard;
return g_clip;
Bool DoCopy( BaseDocument* doc )
Clipboard* clip = GetClipboard();
if( !clip ) return TRUE;
AutoAlloc<AtomArray> active;
doc->GetActivePolygonObjects( *active, TRUE );
if( active->GetCount()>0 )
    ModelingCommandData md;
    md.op = NULL;
    md.arr = active;
    md.doc = doc;
    md.result = NULL;
    md.mode = 0;
    md.flags = 0;
    md.result = NULL;
    SendModelingCommand( MCOMMAND_SPLIT, md );
    clip->TakeObjects( md.result );
else clip->TakeObjects( NULL );
return TRUE;
class MenuTest : public CommandData
     public:
          virtual Bool Execute(BaseDocument *doc);
Bool MenuTest::Execute(BaseDocument *doc)
DoCopy( doc );
     return TRUE;
Bool RegisterMenuTest(void)
     // decide by name if the plugin shall be registered - just for user convenience
     String name=GeLoadString(IDS_MENUTEST); if (!name.Content()) return TRUE;
     // be sure to use a unique ID obtained from www.plugincafe.com
     return RegisterCommandPlugin(1000956,name,0,"icon.tif","C++ SDK Menu Test Plugin",gNew MenuTest);
//In main.cpp:
void FreeClipboard();
void PluginEnd(void)
FreeClipboard();
This code can crash reproducable when you do the following:
Create c4d_debug.txt file, so C4d runns in debug mode.
Run C4d.
Make a cube.
Make Editable.
Make a HNWeightTag ( use hn weight tool on some edges )
Select some polys
Call the plug
Quite Cinema
BOOM... wtf..
it only crashes if you run in debug mode, and have the HN tag. I suspect some memory becomes corrupted somehow.
Okay this crash happens when you quit. But i'm also having other crashes which are harder to reproduce.
I have no idea what is going on. Help ??!!
On 11/08/2006 at 12:31, xxxxxxxx wrote:
hmm... if i use this...
array->Flush();
    BaseTag *t;
    while( t = op->GetTag( Tsds ) )
      t->Remove();
      BaseTag::Free( t );
... the entire plug appears to work just fine.
best regards
Michael
On 17/08/2006 at 23:59, xxxxxxxx wrote:
bump
uhm.. mikael, can you reproduce ?
On 18/08/2006 at 14:05, xxxxxxxx wrote:
Sorry, I thought that the last piece of code you posted was a fix. Perhaps I should take the time to actually read this thread through now... 🙂
On 19/08/2006 at 10:21, xxxxxxxx wrote:
Yes please check it out. The code is no fix, it removes the HNWeight-Tags which seem to cause the problems. It should work with all kind of tags though.
Thanks
On 28/08/2006 at 01:31, xxxxxxxx wrote:
You should use:
C4DPL_ENDACTIVITY
in PluginMessage otherwise (from the sdk docs) :
Sent to all plugins before any PluginEnd() has been called. This allows you to close dialogs, end threads, delete temporary/undo buffers etc. In PluginEnd() it might crash as some resources from other plugins might already be freed.
HTH.
On 28/08/2006 at 02:53, xxxxxxxx wrote:
Thanks David.
