On 24/07/2006 at 10:45, xxxxxxxx wrote:
User Information: Cinema 4D Version: 9.6 UB Platform: Windows ; Mac ; Mac OSX ; Language(s) : C++ ;
--------- Hi all
i'm trying to compile my 2 plugins for UB and i got not problems.. except for the plugin ID
pathdeformer and nota have different ID and they work on PPC Osx and Windows. When i try to use them Universal i got collision of ID.. but the ID are correct. There is any bug about this? I recompiled, cleaned a lots.. but nothings is working.. always collision of ID. I hope that i'm the problem but really all seem to be ok.
Thanks Renato T.
On 25/07/2006 at 18:30, xxxxxxxx wrote:
Sorry, I haven't heard any other reports of this behaviour with the UB version. Perhaps you have two versions of each plugin? You could try setting breakpoints in the loader functions to see that the code is really executed.
On 25/07/2006 at 22:07, xxxxxxxx wrote:
I'll do Michael.
Cheers RenatoT
On 26/07/2006 at 23:18, xxxxxxxx wrote:
Xcode usually has several versions of the compiled .dylib in subfolders, perhaps that's the problem in your case
On 27/07/2006 at 04:57, xxxxxxxx wrote:
Thanks for the infos
Renato T.
On 27/07/2006 at 21:03, xxxxxxxx wrote:
I compiled FastFur 2.0 on Xcode and it work
but now.. i got collision with Nota and Pathdeformer.
This is really strange.
There is anyone that compiled 2 or more UB plugin on xcode? (i know that maxon do that)
Cheers Renato
On 27/07/2006 at 22:03, xxxxxxxx wrote:
After 2 hours with Xcode.. i find really difficult to compile, because in random mode i get working code or error. Clean All.. and maybe that after 1 or 2 times i can get compiled code.
.. and, can someone tell me how i can "Build and Debug" in Xcode?
In the Documentation i tried to find information but the "Build and go" "Build and Debug" are not in the help. All i found is absolutely useless.
This is really frustrating, now i have 3 plugin with different ID that collide with all.
Maybe that is changed the ID way for the 9.5 sdk? Maybe that i have a bugged xcode?
Sorry about that Renato T.
On 28/07/2006 at 02:37, xxxxxxxx wrote:
Ok, sorry for previous post.
I started from zero all with the guide provided by maxon. And now all is working.
Thanks all Renato T.
On 27/05/2008 at 12:58, xxxxxxxx wrote:
I'm just starting to rebuild all of my plugins with XCode so they run on Mac OSX. I'm running into the same problems discussed in this thread (one plugin works fine, but If I compile more than one plugin I get conflicting plugin ID errors). No matter how many times I start from scratch I always get these same errors, even though each of the plugins have a unique ID.
The one thing I have noticed is that the xcodeproj in the resource\_api_lib directory only seems to get compiled once. Whereas with Microsoft Visual Studio 2005 it gets compiled once for each project (or plugin) and seems to work just fine.
I'm using Xcode 3.0
Thanks in advance, Josh
