Getting Midpoint using array(?)
    On 22/06/2006 at 05:08, xxxxxxxx wrote:
    Cinema 4D Version:   9.1+
    I need some help understanding using arrays.
    What I'd like to do is using the selected points in a PointSelectionTag.
    Add those points positions and divide by the amount of points to get a mid position.
    I come as far as the code below, I get the indexes and corresponding positions,but cannot get the grips of using an array to store and calculate them.
    Given that the result allready is an array, as it looks, I might be on the wrong track, maybe.....
    I -assume- I'll have to use an array for this, if not is there a better way?
    Lennart
    main(doc,op)
    var link = op#ID_USERDATA:1; // A object in a linkfield
    if(link->IsInstanceOf(Tpointselection) !=FALSE) // If it is a PointSelectionTag run
    println("YES"); // It´s a pointselectionTag
    else
    println("NO");
    return;
    // Get the selected points , index and position
    var pointsel = link->GetSelection(); // get whats stored in the Tag
    var count = link->GetObject()->GetPointCount(); // get the amount of points in the object
    var i=0;
    var found=0;
    for (i=0; i< count; i++)
    if(pointsel->IsSelected(i))
    found++;
    println(link->GetObject()->GetPoint(i)); // Prints the selected points position(s) as an array
    println(i); // print the indexes of the points
    println(found); // prints the amount of selected points
    Here I need to add all selected points positions and divide by found to get the avarage position
    On 22/06/2006 at 09:03, xxxxxxxx wrote:
    not sure why you want an array for this, but simply use a vector for this.
    Just before your for loop set
    var p = 0;
    and in your loop
    p += op->GetPoint(i);
    then right after your loop, simply divide the sum by your variable "found".
    p /= found;
    that´s it. Or did you want to do anything else?
    Samir
    On 22/06/2006 at 15:51, xxxxxxxx wrote:
    No, this is very much what I'm after, thanks!
    I just have to init the positions as vectors as well and it should be fine:)
    Lennart
