On 13/06/2006 at 16:46, xxxxxxxx wrote:
User Information: Cinema 4D Version: 9.521 Platform: Windows ; Language(s) : C++ ;
--------- Kind of confused on this one: Whenever I switch the project file to Active(Release) to perform the final build of a plugin, the console in Cinema will say that it has a conflicting ID with the same plugin. What's weird is that its fine when the project is set to Active(Debug). I am using a unique plugin ID, so I am having trouble finding where in the plugin that the ID is getting duplicated. I derived this plugin from the MenuTest SDK example if that helps any. I'm also using Visual Studio 2003.NET as my IDE. As always thanks in advance for any help. Josh
On 15/06/2006 at 09:01, xxxxxxxx wrote:
OK, found the problem. There was just duplicated CDL files in the plugin folder; one from the Debug build and the other from the Release build. Once I deleted the CDL file from the Debug build everything was fine. Just posted this incase anyone else runs into the same problem. Josh
On 16/06/2006 at 04:05, xxxxxxxx wrote:
Thanks, I have had similar problems. I'll try your solution.
/Filip
