On 22/05/2006 at 02:49, xxxxxxxx wrote:
User Information: Cinema 4D Version: 9.6 Platform: Language(s) : C.O.F.F.E.E ; XPRESSO ;
--------- Hi all, I'm a COFFEE developer and I've a question for you: I need to access the last rendered frame and display it in a custom picture viewer. Is it possible to render a view via COFFEE and then pick the rendered image? Thanks in advance... Riccardo
On 24/05/2006 at 00:30, xxxxxxxx wrote:
I don´t think you can grab the rendered image with COFFEE. You can start the rendering I think with SetCommand (or anything similar, I am not into COFFEE anymore), but retrieval is not possible afaik.
Katachi
On 24/05/2006 at 03:55, xxxxxxxx wrote:
Thanks for the help. Actually it's possible to render the active view in COFFEE using CallCommand(), but it seems impossible to grab the resulting image. Think I'll use the C++ SDK instead of COFFEE. Riccardo
On 24/05/2006 at 06:37, xxxxxxxx wrote:
yep, isn´t it the same I said?
