On 07/05/2006 at 00:00, xxxxxxxx wrote:
User Information: Cinema 4D Version: 9.102 Platform: Windows ; Mac ; Mac OSX ; Language(s) : C++ ;
--------- I'd like to know how one should proceed with calculating a demo expiry other than 14 days (say 30 or 90 days). It is difficult to test since once you enter a valid registration, it is cached some place. Also, it would not be practical to actually wait 30 or 90 days to see the results.
Thanks,
On 07/05/2006 at 01:25, xxxxxxxx wrote:
Not sure if this is what you want. For longer expirations here is an example straight out of one of my plugins:
LONG exptime = curdate-regdate; LONG expired = 30; //this is how long the demo should run if(exptime<expired) { //The demo is not yet expired //if it´s only 2 days left... if(exptime>=expired-2) //this will tell the user (cinema 4d gives a msg) return SN_EXPIRE_14-(expired-exptime); }
Hope that helps. Katachi
On 07/05/2006 at 01:30, xxxxxxxx wrote:
Thank you very much, Katachi!
On 09/06/2009 at 16:40, xxxxxxxx wrote:
Hi Folks, Any suggestions for making an expiring demo that can't easily be reset by trashing the StartTime/product key file from User/Library/Preferences/Maxon/CinemaWhateverVersion/prefs/ ? I need to collect data on the number of people using a little plugin I plan to release this week and I'd like to compare the number of raw downloads to the number of people that actually register after a very short trial period. I currently bury a StartTime in the product key file and use it to expire the demo version as implied in Katachi's example above. Works fine, but the user can just trash the pref file and get a fresh start rather than being forced to register (a painless but necessary process). My approaches to avoid this:
I think it would also be handy to compile the serial file before I write it so I don't have to create my own encryption algorithms for storing simple things like start dates... I notice that 3Dkiwi's amazing Python wrapper plugin seems to do this. It would be easy if I could place the compiled file in the same folder as the plugin, but since that is illegal, I'd have to place it in User/.../prefs. Problem is, if the compiled serial file lies outside of the Applications/Maxon/C4d/plugins/myplugin..., I can't "include" it into the original plugin, so I'd appreciate any suggestions on this as well.
On 10/06/2009 at 00:52, xxxxxxxx wrote:
You could use Read/WritePluginInfo or alternatively Read/WriteRegInfo in a license server enviroment to read/write data to the Windows registry or the OSX preference files.
On 10/06/2009 at 14:52, xxxxxxxx wrote:
Woops, I didn't realize when I tacked on to the end of this discussion that it was for C++. I'm guessing this is all beyond C.O.F.F.E.E.'s grasp.
