MergeDocument()
On 06/05/2006 at 05:47, xxxxxxxx wrote:
Cinema 4D Version: 9.5
Platform: Windows ; Mac ;
Hi,I tried to merge a scene into the currently active document and MergeDocument returns TRUE, but nothing is merged into the scene. :-/
Anybody knows how to use MergeDocument() or why it´s not workign?
BaseDocument *doc=GetActiveDocument(); if (!doc) return FALSE; MergeDocument(doc,this->file,SCENEFILTER_MERGESCENE,NULL);
On 16/05/2006 at 00:47, xxxxxxxx wrote:
So, doesn´t it work or am I doing sth wrong?
How is one supposed to develop when you need to beg for an answer?
On 16/05/2006 at 06:35, xxxxxxxx wrote:
MergeDocument() is new to the R9.5 SDK, so I've never used it. You're probably one of the first to do so. :)
What you're doing looks proper from reading the documentation. Does the loaded document show anywhere (unmerged, for instance) or does it just not load at all?
On 16/05/2006 at 06:41, xxxxxxxx wrote:
Hi Kuro,
it simply doesn´t load at all. I don´t get any memory leaks but the function returns TRUE! It really seems to do nothing! :-(
On 16/05/2006 at 08:22, xxxxxxxx wrote:
What kind of document is it? A .c4d I would suppose. Have you tried other files and file types, .obj for instance?
Looking at 'c4d_basedocument.cpp', it appears that SCENEFILTER_MERGESCENE is already OR'd into the flags. Try it without any flags (0L), if you haven't already.
On 16/05/2006 at 08:50, xxxxxxxx wrote:
yep, it is c4d. Also tried other formats. And I of course already tried any kind of FLAG combination already. :) No difference though. :-(
On 16/05/2006 at 13:29, xxxxxxxx wrote:
I'm sorry, the docs are a bit misleading. In my experiments I need to have SCENEFILTER_OBJECTS|SCENEFILTER_MATERIALS in order to make both LoadDocument() and MergeDocument() actually do anything. This is the code I used:
Filename fn1; fn1.FileSelect(); BaseDocument* doc1 = LoadDocument(fn1, SCENEFILTER_OBJECTS|SCENEFILTER_MATERIALS, NULL); Filename fn2; fn2.FileSelect(); MergeDocument(doc1,fn2, SCENEFILTER_OBJECTS|SCENEFILTER_MATERIALS,NULL); InsertBaseDocument(doc1); EventAdd();
On 16/05/2006 at 13:33, xxxxxxxx wrote:
Thanks Mikael! Now I see what LoadDocument has to do with it! Great, will try that. Thanks finally!
On 14/06/2009 at 11:50, xxxxxxxx wrote:
Just found this solution, but i'd like to understand why i need to use LoadDocument and cant use the current ActiveDocument as the base?
cheers,
Ello
