Dialogs, Dlggroup and AskClose ...
    On 07/04/2006 at 07:12, xxxxxxxx wrote:
    Cinema 4D Version:   R9.5
    Platform:   Windows  ;
    I am trying to set up a simple menu plugin launching a dialog (class GeDialog) for user input. All this works fine, until i get to closing the dialog and working with the results.
    I added a dialoggroup with ok and cancel
    DLGGROUP { OK; CANCEL; }
    and thought it would be handled by C4D, but that's not the case. So if I just run it like that, the buttons are there, but nothing happens when I click them.
    I can look for the ID's (id==1 or id==2, is there another way to reference the DLGGROUP elements, like id==DLG_OK or so?) and then close the dialog manually in the
    command(id, msg)
    ... but then again: when is
    AskClose()
    called? I thought this would be called automatically upon closing the dialog.
    Of course I can call it manually again, but there must be a "cleaner" way of programming it using C4D's features ... I just can't find it ...
    Juergen
    On 07/04/2006 at 08:29, xxxxxxxx wrote:
    Ok ... main stuff is working now, I figured it out somehow. Just one more thing remains:
    Can I force the plugin to skip
    AskClose()
    when the cancel-button is pressed? Because both buttons (Ok/Cancel) are followed by a
    Close()
    command, but I only want to check for input errors on OK.
