On 05/04/2006 at 07:10, xxxxxxxx wrote:
User Information: Cinema 4D Version: 9.x Platform: Mac OSX ; Language(s) : C.O.F.F.E.E ;
--------- Imagine I have the following string:
var st="áéíóú";
if I perform a println(st); I get:
áéíóú
Correct!! Now, if I do the following:
println(st[2]);
I get:
237
Ok, I have to convert it to a character, so I do the following:
println(tostring(st[2],"c");
but I get:
Ì
instead of "é". "Ì" was not even in the original string!!
How can I get individual characters from inside a string, correctly evaluated? Thank you very much in advance for any solution.
Rui Batista
On 06/04/2006 at 12:53, xxxxxxxx wrote:
Do:
var st="áéíóú"; var i = 2-1; println(strmid(st,i,1));
Note that strings are of course 0-indexed as well as arrays in C.O.F.F.E.E.
On 06/04/2006 at 16:43, xxxxxxxx wrote:
Thank you, Mikael. The solution I found is not far from it. This is what I did:
add_char(line,char) { if(char<127) line=stradd(line,tostring(char,"c")); else line=stradd(line,strmid("?áéíóúàèìòùÁÉÍÓÚÀÈÌÒÙãÃâÂêÊîÎôÔûÛçÇñÑäÄëËïÏöÖüÜ",strchr(" áéíóúàèìòùÁÉÍÓÚÀÈÌÒÙãÃâÂêÊîÎôÔûÛçÇñÑäÄëËïÏöÖüÜ",char),1)); }
While calling this routine with add_char(&line;,char);
