Undo and BaseContainer
    On 03/04/2006 at 11:42, xxxxxxxx wrote:
    Cinema 4D Version:   9.5
    Platform:   Windows  ;
    Hi everyone!
    I have implemented a tag plugin which do some modifications on the points of an object thanks to sliders.  Several sliders can be added by the user and their values are used for the modifications.  Each time a slider is modified, the modification is made with a code like this one:
    // Modifications on the points selected by the tag
    doc->StartUndo();
    Bc.SetContainer(3000, m_vector);
    data.SetContainer(MYID, Bc);
    tag->SetData(data);
    tag->Message(MSG_UPDATE);
    doc->AddUndo(UNDO_CHANGE, tag);
    doc->EndUndo();
    where Bc is a BaseContainer in which my data (m_vector an other BaseContainer which contains several data) are stored.
    When I add two sliders and change the sliders values and next do Undo in Cinema4d, the two sliders are removed when the Undo should affect only the laste modification on the points.
    Does somebody have an explanation?
    Thanks a lot.
    On 03/04/2006 at 12:32, xxxxxxxx wrote:
    Attribute Manager changes usually store undos automatically, so you don't need to do undo wrapper. (?) Try it with those commented out and see if it makes a difference.
    Additionally, if you are doing this for every slider change, the undos will rack up quickly (and your undo buffer will only contain the last capture slider movements).
