On 27/03/2006 at 03:14, xxxxxxxx wrote:
User Information: Cinema 4D Version: 8.5 Platform: Language(s) : C++ ;
--------- Hi. Ive recently shifted to c++ from coffee, and find the 8.5 material system difficult to use... I need to create a new bitmap shader. I can do it using basechannels, grabbing ,say, the color channel and reading/assignong its bitmap. I know that basechannels are now old hat, but how do you create a new shader[xbitmap] and then assign a new bitmap to it? Can someone show me a quick example how to do this? The prob I have is the basecontainer IDs. With basechannels you can set a new filename for the InitTexture to find , but what are the IDs for an xbitmap ? Is it okay to continue using basechannels? Will they suddenly be removed from future versions......? thanks for ANY help at all.... tone.
On 27/03/2006 at 09:21, xxxxxxxx wrote:
Hi. I just need to understand the ethos of materials now... If you attach a new shader to a material, how do you decide which material channel it is working for? e.g. create a noise shader and apply it to the material`s color channel.. anyone..........?
On 29/03/2006 at 08:02, xxxxxxxx wrote:
References to Shaders are now stored in BaseLinks. So you can just do mat->GetDataInstance()->GetLink( MATERIAL_COLOR_SHADER, doc, Xshader ) to get the shader in the color channel for example. The id's can be found in mmaterial.h in the resource/res/description folder.
Some of the shader headers are in resource/res/description But most of them are in resource\modules\shader\res\description and modules\CINEMA 4D\sla\res\description
Look for files like Xshadername.h The id's for the Bitmap shader are in resource/res/description/Xbitmap.h
To give a channel a bitmap texture you would do something like: PluginShader* shd = PluginShader::Alloc(Xbitmap); shd->GetDataInstance()->SetFilename(BITMAPSHADER_FILENAME,"texture.jpg"); mat->GetDataInstance()->SetLink( MATERIAL_COLOR_SHADER, shd );
Of course, don't forget to check the result of allocations, delete shaders that are not needed anymore.. well you know.. all the memory management stuff that is not needed in coffee..
On 30/03/2006 at 02:09, xxxxxxxx wrote:
Thanks Michael.... I know you pros are generally too busy to help new starters with the basics, but this is much appreciated. cheers.. tone.
On 30/03/2006 at 07:39, xxxxxxxx wrote:
Hmm.. Sorry for sounding thick, but I can use the above to make noise shaders etc. but cannot make a new LayerShader. . I assume you use Insertshader to add layers to an Xlayer.. and then link to a full-blown LayerShader... but can`t seem to get it to work. cheers...
On 30/03/2006 at 11:23, xxxxxxxx wrote:
the Layershader is quite special. From the R9.5 SDK upwards, there is a library to deal with it. Look for lib_layershader, or so. If you can't find there what you need, i guess you are out of luck. InsertShader will not work i think.
On 30/03/2006 at 11:27, xxxxxxxx wrote:
Ah well.. can`t win em all...... ta.
