Need a coffee script to build a spline
On 09/03/2006 at 02:36, xxxxxxxx wrote:
Dear engaged cinema friends, I have started to work with some simple coffee scripts last weekend. I am looking now for a code line for "creating a spline", want to make some experience with (helix, spline curves manipulation and so on) it and would like to adapt a splinetool from another program to cinema, the tool will be for free, if I have adapted it to cinema 🙂 I haven't found any advices in the sdk 9.5, or overread it. Perhaps somebody can help me? best regards from raining and snowing germany, frankolino :-))
On 10/03/2006 at 04:23, xxxxxxxx wrote:
Hi dear Cinema User, I have found such things yesterday and perhaps somebody can say, if this code lines are useful for creating a splinecurve with coffee ! 🙂 have a good weekend, bye, frankolino 🙂
main(doc,op)_<_o:_<_o:p_>_o:p>
_rve=op;
var bc;
if (instanceof(curve,SplinePrimitiveObject))_<_o:_<_o:p_>_curve->GetSplineObject();
_nstanceof(op,SplineObject)) return;
_o-fareast-font-family: 'MS Mincho'">
curve->InitLength(1);
var long=curve->GetLength();   //länge der spline_si-language: FR; mso-fareast-font-family: 'MS Mincho'">s
var inter=lenght/(nb_objets);   //berechnet die Intervalle der splines_e="mso-fareast-font-family: 'MS Mincho'"> (splines geschlossen)
bc=cur_RU style="mso-fareast-font-family: 'MS Mincho'">ve->GetContainer();
var close_="mso-fareast-font-family: 'MS Mincho'">=bc->GetData(SPLINEOBJECT_CLOSED);
_"mso-fareast-font-family: 'MS Mincho'">if (close==FALSE) inter=length/(nb_objets-1);<_<_o:_<_o:p_>_/P>
var object=op->GetDown();  // er_<_o:_<_o:p_>_...
if (!object) return;
var source_object=object->GetName();<_<_o:_<_o:p_>_class=MsoPlainText>var rot_s=objet-&g;_<_o:_<_o:p_>_()->GetHPB();
and so on...
On 10/03/2006 at 14:50, xxxxxxxx wrote:
For Xpresso, COFFEE, C++ development, you would probably get a quicker response if you ask in the "SDK Help" forum. 🙂
Also, doing a search in that forum (with All to go past the current month) may provide the answer without even asking.
On 13/03/2006 at 04:44, xxxxxxxx wrote:
Thank you Robert! I have done it ;-), best regards, Frankolino 🙂
