On 04/03/2006 at 22:18, xxxxxxxx wrote:
User Information: Cinema 4D Version: 9.102 Platform: Windows ; Mac ; Mac OSX ; Language(s) : C++ ;
--------- No matter what I do, there seems no sane way to reference the DescLevel of the DescID in a DescriptionCheckUpdate structure (no examples either). Since it is a pointer, the [] operator will not compile on dcu->descid[0].id. So I figure it needs to be dereferenced. But all my varied attempts so far equal compiler error or a Cinema 4D crash - specific to the marked lines:
// React on Figure object dropped into IPPFIGURE_CONFORMTO else if (MSG_DESCRIPTION_CHECKUPDATE) { DescriptionCheckUpdate* dcu = static_cast<DescriptionCheckUpdate*>(data); // +CRASH DescID descID = *(dcu->descid); if (descID[0].id == IPPFIGURE_CONFORMTO) // -CRASH { BaseDocument* baseDoc = node->GetDocument(); if (!baseDoc) return FALSE; BaseContainer* bc = ((BaseTag* )node)->GetDataInstance(); if (!bc) return FALSE; if (!node->GetDescription(desc,0)) return FALSE; BaseObject* obj = bc->GetObjectLink(IPPFIGURE_CONFORMTO, baseDoc); if (obj) GePrint("Conform To: "+obj->GetName()); } }
I've tried (*(dcu->descid))[0] (no compile) and ((DescID)*(dcu->descid))[0] (crash) among others. Is there any way to get this dereferenced in order to apply the DescLevel operator!? It is the ONLY way to get at the DescLevel...
Thanks,
On 04/03/2006 at 23:36, xxxxxxxx wrote:
Ah, nevermind. I see that a similar dereference in the API code is commented out (wonders why...). I'll just use a darned BUTTON resource.
